Old 11-06-2019, 08:55 PM   #1
used 4.10 Rockwell 145 series gears $150+shipping
like the title says I have a used set of 4.10 Rockwell 145 series gears.
$150 + shipping
Shipping weight is about 55 lbs I am at zip code 45645. (I think the ring gear is about 16 inches in diameter.)
usually on a axle you will typically see RS145-20
which means Rear Single(axle) 145 series - 20K (lb rating)
I will include this so people can calculate.
MPH X Gear ratio X 336 / overall tire height in inches = RPM
Mekanic is offline   Reply With Quote
