Old 06-17-2017, 09:17 AM   #1
upbeat's Avatar
Year: 1974
Chassis: Supercoach - Single Axle
Engine: Cummins NH-250, Fuller T-905M
Wanted: Eaton Fuller RTO-910
That's the overdrive model of the ten speed. I'm in Sam Francisco CA - Closer the better.
Thanks
upbeat is offline   Reply With Quote
Old 06-17-2017, 01:56 PM   #2
Chassis: IH
I'd be a little surprised if anyone here has one for offer, I'd check some truck junkyards.
Old 06-17-2017, 01:57 PM   #3
upbeat's Avatar
Year: 1974
I'm open to being surprised . Will also search the web and the yards.
Old 06-17-2017, 03:13 PM   #4
Engine: Detroit Diesel 6-71
Rated Cap: 52 pax
I'm looking for that same exact trans for my '76.
-Chevy
Chevydude01 is offline   Reply With Quote
Old 06-17-2017, 03:47 PM   #5
Chassis: IH
Quick question, would changing the rear-gear ratio be objectionable? It would achieve the same end of greater top speed and lower RPM at a given speed. It may prove cheaper and easier than a transmission swap.
I can get the "chunk" re-done locally for about $850. Removal and re-installation is within the realm of DIY (adjusting the gears and everything is probably best left to experienced experts).
Old 06-17-2017, 04:09 PM   #6
Robin97396's Avatar
Pardon my lack of knowledge on this subject, but are you referring to the stick shift RTO. I don't remember where of course, but within the past couple days I've seen one. It was removed from a roll-off truck with about 186,000 miles while still in working condition, replaced with a different type of transmission.
I'll look for it. The photo was really poor and it's in an add that didn't look like anything important. Easy to miss.
Robin
Nobody's Business
Old 06-17-2017, 04:31 PM   #7
Rameses's Avatar
If it came out of a rolloff it's probably a heavier RTO. An 11908LL or an 11613.
Rameses is offline   Reply With Quote
Old 06-17-2017, 04:45 PM   #8
upbeat's Avatar
Year: 1974
Great. Let's find a couple and get them in.
