Old 01-08-2020, 01:07 PM   #1
Coachwork: Ic
Chassis: No idea man
Engine: Dt466e
Rated Cap: Tons 0’ kids
Wanted- governor removal
I have a 2004 international skoolie with a dt466
I’m looking for someone in the Nashville area that can remove my road speed limiter, activate cruise, and bump horsepower
Let me know if you have the tool, and what you’d charge
Crawlerdan is offline   Reply With Quote
Old 01-10-2020, 12:16 AM   #2
Engine: DT 466 Mechanical spicer 6+1. & 5.9 Cummins
Wrong place
You should post this under the mechanical section forum on this website. Probably won't get much action here
alexzckary is offline   Reply With Quote
Old 04-09-2020, 07:38 AM   #3
which state? theres prob plenty of governors that need removed
bfennel is offline   Reply With Quote
Old 04-09-2020, 07:42 AM   #4
Coachwork: Ic
Engine: Dt466e
Bah dump tiss. I agree
Old 04-09-2020, 08:24 AM   #5
I can do it but im in ohio and the coronavirus thing means im not running 1000s of miles all over the country right now like I usually do..
of course governor and HP depend on what you are set at now.. on a 466E the hardware changes when you get up to the 215HP mark.. the HT versions have different internals, turbo, and injectors than the standard models..
Governor depends on rear gears.. if you are maxxed out at 2500-2600 RPM when hitting your Max speed then your hardware is limited and computer program wont make any difference..
