Old 02-11-2016, 04:36 PM   #1
Wanted Tow Plate
I need a 2 inch receiver and plate to adapt to my 95 Ford. Am also in need of a electric brake setup for the trailer, and a Jake brake for a 5.9 12v Cummins. Feel free to call/text me at 203-666-9163, or ejcon1@gmail, Thanks, E
EJCON is offline   Reply With Quote
Old 02-11-2016, 04:43 PM   #2
Not sure what you mean by a tow plate.
You can bolt or weld a 2" hitch receiver to just about any school bus rear bumper. Or you can fabricate a mount that can bolt to the frame in front of the rear bumper.
Almost any electric brake controller that uses a pendulum or timer to apply the electric brakes will work. Just be aware that if the bus is new enough to have a multiplexed electrical system you can't just splice into the brake light circuit to send a signal to the electric brake controller.
Blue Ox and others make exhaust brakes that will work on the 5.9L Cummins. A true Jacobs Engine Brake system is not available for that family of engines.
Old 02-11-2016, 04:43 PM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
etrailer.com
Old 02-11-2016, 05:13 PM   #4
Yeah, I understand all that but more like: used-cheap-preowned-boneyard-salvage-distressed
Old 02-12-2016, 01:49 PM   #5
Rated Cap: 40 Prisoners
Found my tow hitch on craigslist off a 1995 Ford F250. The F250 - F350 has
approximately 33 inch distance frame spacing, so I was able to trim off a
couple ears and add a couple of spacers and tabs and had a class 5 receiver
that bolted onto the bumper and under the tow hooks. Cost of receiver was
$50.00.
Old 02-12-2016, 04:04 PM   #6
That's what I'm talking about, Thanks
Old 02-12-2016, 04:06 PM   #7
Post tow plate
not sure what any of that means but following closely in case I understand and Cowlitzcoach..... u sure know your stuff!!!!!!!!!!!!!!..I hope your around when I start my bus.....see ya...jim
busdognana is offline   Reply With Quote
Old 02-12-2016, 11:18 PM   #8
crazycal's Avatar
http://www.skoolie.net/forums/f27/fr...0-a-10703.html
http://www.skoolie.net/forums/member...albums693.html
I'm hungry!
You Gotta Let Me Fly
