Old 05-28-2018, 07:50 AM   #1
WTB 4x4 Skoolie
Title says it all. I'm looking for a converted or partially converter skoolie 4x4 for an North-South Overland trip of the Americas. Located in Ottawa, Canada but will travel for "the one".
Cheers!
DarkBladeRunner is offline   Reply With Quote
Old 05-28-2018, 09:33 AM   #2
Chassis: B3800 Short bus
What's your budget?
4x4 buses tend to be a rare breed. Mostly they will be van cutaway style. Take a look at online auctions with Colorado buses.
If you have the cash it may be easier to grab a van cutaway bus closer to home and have them do the 4x4 upgrade.. But it'll surely cost Ya
Old 05-28-2018, 09:36 AM   #3
A cheaper option would be to grab a typical rwd bus and add a diff lock. Might have to swap the whole rear axle with one from a wrecked dump truck or something.. Not too bad of a job, just heavy
Old 05-28-2018, 10:33 AM   #4
How much work are we talking about? My overall budget is 30-40k ish.
I found a converted 1975 blue bird flat nose w/ Diesel Cummings engine at fair-ish price but I don't like the ground clearance on it. If changing out the rear diff is it realistic to lift the bus 10 inches, put better and maybe larger tires? Bus has only about 10 inches of clearance now.
Any Idea on budget for this?
Old 05-28-2018, 10:40 AM   #5
Cheers!
https://www.youtube.com/watch?time_c...&v=ONkSV7SKW_Q
Its already sold four years ago. But they're out there. Good thing you've got deep pockets. You should be able to find a real 4x4 bus.
Roll Your Own Build Thread
Old 05-28-2018, 10:40 AM   #6
Only 10" clearance on a Blue Bird? Are you talking about below the diff and front axle, or the body because the skirt of mine is closer to 24" high. Or maybe the bumper? I know that many of the flat nose buses have a dropped bumper.
30-40k should get you a good (no, amazing) 4x4 conversion. Again, the cut-away van style will be easier to figure out. Check out Z.E.U.S.V III: http://www.skoolie.net/forums/f27/4x...uild-18314.htm
Old 05-28-2018, 10:42 AM   #7
That is a sweet find! The comments say it's around $10k, which isn't so bad for a full 4x4 conversion, I'd say. Not sure how correct Youtube comments are going to be, though
Old 05-28-2018, 10:48 AM   #8
If I found one of those for 10k, I'd go take out a loan and buy it.
Old 05-28-2018, 10:53 AM   #9
Found this site, they sell bus 4x4 conversions.
4 x 4 bus buys, refurbishes, customizes and sells 4 x 4 school buses to be used by resorts, reserves, lodges and tours
Old 05-28-2018, 10:54 AM   #10
Not much ground clearance as you can see.
Also: thanks for the conversion link.
