Old 06-13-2019, 10:28 AM   #1
Dèsirée's Avatar
Important: Moderator Needed
Originally Posted by Janet H View Post
Editing your posts
Posts can be edited for a few hours after they are posted. If you need to change post content after the edit window has expired, please contact a moderator for help with this. In general you can simply post an update to a thread if there is new information but in the case of a recipe or instructions on how to do something (for example) that needs to be corrected, a forum moderator can help you make these changes.
I need to edit content of a posting made. The instructions above are very vague. Seeking a Moderator who can delete entire posting, or instructions on how to do it.
I thank you in advance for your prompt attention,
Dèsirée
Dèsirée is offline   Reply With Quote
Old 06-13-2019, 11:10 AM   #2
Multiple posts doesn't help, only annoys.
Old 06-13-2019, 11:18 AM   #3
Dèsirée's Avatar
I was under the impression, each forum was independent... so members in one forum, would not get other forum’s posting unless they were also members of that specific forum.
I posted through several forums, so you will definitely be annoyed with me.
My apologies!
Old 06-13-2019, 11:22 AM   #4
My apologies!
If you look to the right there is a column showing every new post, irrregardless of forum. You've made about 5 separate threads on your issue. Janet will get to you eventually.
Old 06-13-2019, 11:24 AM   #5
Dèsirée's Avatar
Sorry about that. I’m using my iPhone. I don’t see the entire site.
Old 06-13-2019, 12:03 PM   #6
HazMatt's Avatar
Chassis: IH 3800, 8 window
"Irregardless" is barely a word...
"Regardless" means, literally, "without regard."
The IR- prefix is not only redundant on this misbegotten little bastard of a word, when conjoined with the -LESS suffix, it becomes a double-negative.
Ethically, two wrongs don't make a right, but mathematically and grammatically, two negatives make a positive.
Old 06-13-2019, 02:17 PM   #7
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Matt;
I about died laughing with this post. The English language is a convoluted coagulation of so many other languages the only way to make sense of it is to apply mathematical logic and sort the mess out!
A+ for effort!
M
M1031A1 is offline   Reply With Quote
Old 06-13-2019, 03:03 PM   #8
HazMatt's Avatar
It is always good to know when one's good intentioned good interests are good enough to score four(point-oh). Better than the grade typically awarded for, "Effort!"
Not that I have the least fondness for alliteration, but "convoluted coagulation" is a good 'un! English is a BIG bastard, with innumerable Daddys contributing to the stew.
Originally Posted by M1031A1 View Post
Matt;
A+ for effort!
M [emoji3]
