Old 10-18-2015, 08:44 AM   #1
Rear Engine Bus Fire Montgomery MD
School bus catches fire in Montgomery County
Old 10-18-2015, 10:29 AM   #2
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
This almost doesn't qualify as news anymore!
We sold all our rear engine buses we got from Montgomery County after we had one burn down on us in the yard and take out the bus it was parked next to as well.
We didn't figure out what caused it
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 10-18-2015, 10:31 AM   #3
It does seem more common than it should be.
Old 10-18-2015, 10:35 AM   #4
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
When I see Thomas and BB REs, all I can think of is just how little air there is circulating around the power plant coupled with that tiny radiator, versus the engine bay and radiator of an International RE. Biased in my opinion? Probably.
Captain Obvious on deviantArt
Old 10-18-2015, 10:56 AM   #5
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
I read somewhere that at one point in time, those buses had hydraulic actuated fans that could catch fire due to a hydraulic leak.
RHOMBUS is offline   Reply With Quote
Old 10-18-2015, 11:01 AM   #6
My friends Thomas has that setup.
Old 10-18-2015, 01:18 PM   #7
Engine: 190hp 5.9 Cummins
Almost every rear engine bus fire is caused by lack of maintenance. The hydraulic actuated fans run engine oil, from the same pump as the power steering.
When the hydraulic actuated fan motors front seal starts to leak, it sprays hot oil into the fan, that then blows the oil all over the hot turbo and exhaust manifold.
We run just under 100 rear engine buses in both Bluebird and Thomas.
To date, due to our diligent maintenance, we have not had a single bus fire in our fleet of over 400 buses.
Old 10-19-2015, 03:48 PM   #8
Engine: 3208 turbo Cat
Ok, you guys just scared the pants out of me, what kind of maintenance can I provide to the hydraulic actuated fan to minimize leaking and prevent fires?
J
juliol is offline   Reply With Quote
Old 10-20-2015, 11:32 PM   #9
Just watch for leaks, and when they happen, fix the leak.
It starts slowly, not suddenly.
Old 10-21-2015, 05:26 AM   #10
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
That particular model of Thomas RE also has a manufacturer's defect with the battery cables being pinched between the chassis and body. Last year FOUR of our '04 Thomas RE Saf-T-Liner buses went up in flames the same way, IN OUR PARKING LOT without the keys in the dash, or the vehicles ON. CHECK THE BATTERY CABLES. We sued Thomas, and won for the defect which caused the recall (along with several other ISD jurisdictions in Texas). I also checked the set-up on Heavy, different configuration.
Just a heads-up from our experiences.
M1031
M1031A1 is offline   Reply With Quote
Old 10-21-2015, 07:36 AM   #11
Outstanding info above...thanks for sharing.
All Thomas RE owners...Take Note!
Old 10-22-2015, 10:29 AM   #12
RHOMBUS's Avatar
Hm. Guess I'll have another look at the cables. My fan is air-actuated, belt driven, so I'm good there.
