Old 12-14-2017, 03:56 PM   #1
Students injured after truck hits school bus in Lake Placid
Anybody else hear about this? It showed up in my FB feed this AM.
Truck hits school bus in Lake Placid - Story | FOX 13 Tampa Bay
Old 12-14-2017, 04:36 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Dang, that truck slammed into the stopped bus. Bus did pretty good, considering.
Old 12-14-2017, 06:01 PM   #3
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
I know there are some opinions on this?
I am going to throw it on the table anyway.
We buy buses because they are built better than stick and staples.
But then we tear everything including the interior roof and wall skin out?
I can kinda go with a roof raise if done properly.
This happened to a school bus with working lights and all and its on its side and the emergency hatches were used.
We are on the same roads as anyone else.
Could or would your roof raise or your build without the interior roof metal still handle this kind of impact and consequences with the roof emergency hatches still intact?
We won't know until someone that has removed the interior skin for insulation and didn't put it back actually ends up in a situation like this?
I don't wish this on anyone but if we buy them for there safety platforms and advantage over a stick and staple then why do we compromise the buses structural safety over ?(it's cheaper and easier??) for me to tear it out and not have the expense to put it back?
SAFETY IN YOUR BUILD. Should be top priority.
I have a dedicated seat belt for anywhere a bodie can set whether required or not.
I do believe my build interior and if I can keep my kids in there seat belts then we would have survived this and I don't have roof hatches?
Old 12-14-2017, 06:13 PM   #4
Chassis: Saf-T-Liner MVP ER
By the look of the front of that Semi, and the fact that the bus was pushed off its wheels and off the road, it was not a gentle hit.
Kudos to the bus. Apart from the obvious damage to the immediate area of the impact, it is completely intact.
The areas of the bus that "may" be slightly compromised by our modifications, are not the areas hit by that vehicle, nor are they likely to be.
It's not really fair to compare the strength of a Skoolie conversion with a School bus. Roof raise aside, we take the seats out and they are integral to the protection of passengers. It's more useful to compare it with the equivalently sized motorhome.
Steve Bracken
Build Thread
Old 12-14-2017, 06:38 PM   #5
Year: 86
Chassis: Ford B700
Engine: 8.2
You are correct .
I was looking at how that same SKOOLIE would do in the same circumstantances with a roof raise and or the interior skin not in place.
It all depends on the builder,there ability, and what they chose was best for them?
Because of my job and experience I will always push safety forward.
Doesn't meen that it always is the safest way to do it for experienced people.
But even though a lot of standards are BS. They are there to protect the new/experienced body you just hired that don't work cause he is the best around but took a job a lot less under you to be able to tell you what you need to do?
Sorry. Trying to wrap my head around work and play here?
I quit bringing my work home 2-yr ago but it's still in my head when I try to?
Old 12-14-2017, 06:47 PM   #6
Originally Posted by Jolly Roger bus 223 View Post
You are correct .
Well it's perfectly reasonable to understand that some changes will have some effect on safety, and/or structural integrity in moments of severe stress.
That way, when we decide to make changes, we can do so based upon a more informed position.
Steve Bracken
Build Thread
Old 12-14-2017, 07:23 PM   #7
Traveling
Rated Cap: '00
Much bigger problem is projectiles. Stuff like: the refrigerator held down with particle board and hardware store l-brackets, dozen car batteries, recliner....
Old 12-14-2017, 07:27 PM   #8
Robin97396's Avatar
Exactly. I don't want a wood stove hitting me in the back of the head.
Robin
Nobody's Business
Old 12-14-2017, 07:38 PM   #9
I see the attraction of a woodstove, especially for full-timers, but some of the installations scare the crap out of me.
I saw a picture just today of a ws right behind the driver's head. I hope it was bolted directly to the frame, but I doubt it.
Steve Bracken
Build Thread
Old 12-14-2017, 08:02 PM   #10
Robin97396's Avatar
There are some scary buses on the road. I'm very cautious of buses that appear to be finger painted and/or have blankets hanging in the windows.
My bus is nothing to brag about. I try to make it very forgetable. If I'm in a accident it's likely I'll get some splinters from all this wood that replaced my interior panels. I work hard at keeping things safe, especially with all the backroad driving I do.
Robin
Nobody's Business
Old 12-14-2017, 08:08 PM   #11
You might want to avoid us then.
We are thinking of a base color, then having "Starry Night" on one side, and "Guernica" on the other.
Our High School Art Program wants a project.
Steve Bracken
Build Thread
Old 12-14-2017, 08:25 PM   #12
Robin97396's Avatar
That's just a tad bit different from what I was talking about. Are you hanging blankets in the windows?
I'm talking about the ones that look like they were attacked by a kindergarten class of angry 6 year olds.
Robin
Nobody's Business
Old 12-14-2017, 08:38 PM   #13
Well if we use it at the "tin tent" stage there may be blankets. It might also still be yellow because Oklahoma doesn't much care either way.
This is a project that will try to do all the basics right, and take our time doing it ... so things will go in phases as finance allows.
That said, I'll try to get it quickly to the point where I can re-title it, something that appears relatively easy here. It's an affidavit and no inspection.
I don't even have to lie to install a bed, stove, fridge and inverter. They can all come out again when the real build gets going.
Steve Bracken
Build Thread
Old 12-14-2017, 08:57 PM   #14
Robin97396's Avatar
I'm still not crossing the line into motorhome territory. I'm registered as a van, so virtually nothing is installed permanently in this maxi-van.
It isn't hard to get motorhome plates. The DMV doesn't really care because they get their pound of flesh either way. It can be hard to get insurance as a self built motorhome, in this state anyway. They really cracked down on hippy buses here, although many years after the real problem occurred.
I'm staying registered as a van until the time when that becomes a disadvantage. That would have to do with my success or failure while attempting to cross a northern or southern border. Time will tell.
Robin
Nobody's Business
Old 12-14-2017, 11:22 PM   #15
Rated Cap: 37,400 lbs GVWR
I really hope the police investigate whether the truck driver was using a cellphone at the time. Cell tower records will always tell. Maybe the truck had an interior dashcam to record what the driver was doing? Or did its brakes fail, and if so why?
Old 12-14-2017, 11:33 PM   #16
Traveling
Rated Cap: '00
I think they mentioned it was a blind hill and a bad stop, but yeah, he snoozing.
