Old 04-26-2004, 07:53 PM   #21
lapeer20m's Avatar
good news for me.......From what i've been reading , apparently the bosch fuel injector pumps are very tollerant of svo. That makes me feel better. I'm still a bit nervous about the conversion causing premature engine falure. (premature at 265,000 miles??? is that some kind of joke?)
The guy at the bus garage says an entire rebuild kit including rings, wristpins, gaskets, seals ect can be purchased for the DT 366 for under a thousand bucks. Unfortunately i don't have an international motor. I have a Ford. The price for a rebuilt ford 6.6 liter is about $10k according the the bus garage mechanic.
My next bus (if i purchase another one) will almost certianly have a DT series motor in it.
I'm very happy with my braziallian made 6.6 liter ford, but parts are rediculously expensive !
Old 04-26-2004, 11:32 PM   #22
Steve's Avatar
So Jason, it looks like the trip to burning man this year wont be so expensive
Old 04-27-2004, 12:32 AM   #23
If you are worried about the engine gumming up you can always take a sample of your oil to a lab and see if there is anything bad going on. You can always put some solvent in the crankcase before you change the oil. If you can find Ron Morrison he has been running his bus on WVO for a long time now. I will try to find out what happened to him.
busone is offline   Reply With Quote
Old 04-27-2004, 06:26 AM   #24
lapeer20m's Avatar
Since my engine is made in brazil, i'm hoping that it is more tolerant than an engine from the USA. I think the quality of fuel from poorer countries is probably not as good as the fuel we have here in our country and would require an engine that can handle differences in fuel as well as increased impurities.
Maybe I just have a wild immagination !
Old 04-28-2004, 08:36 AM   #25
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Originally Posted by lapeer20m
<snip>
Then the oil will be forced through a 20 micron filter followed by a 5 micron water filter. These filters are about 3 dollars each (but $30 for the filter housing)
Why not use an automotive oil filter? They should be cost competetive, and I think they filter down to a smaller level than the filters you mention. Except they may not filter water. Not sure about that.
The end product should be ready for the tank. The tank can't really be much bigger than 30 gallons. The amt of time it takes to heat the oil enough to switch from diesel to veggie will be extended as the tank gets bigger. I think i will mount one or two more 30 (or 35 ?) gallon drums under the bus to hold clean oil. A fuel pump could be used to refill the main svo tank. This would allow quick switching of fuel, but also allow long range between fill-ups.
How about a solar heater? Put a passive solar collector on the roof, and use a small pump (solar electric powered?) to run automotive motor oil through the collector and a heat exchanger in the tank. If the tank is insulated, the solar heater may be enough to keep the WVO liquified adequately most of the time.
How does one go about paying road tax on bio fuel??
Check your state code online. Search for keywords related to motor fuel taxation. In my state bio-diesel may or may not be exempt....most likely not.
The tax applies to fuel commercially available for use as motor fuel....there is *one* outlet in SC that sells biodiesel commercially. That may be the 80/20 diesel/biodiesel, so *PURE* biodiesel would then NOT be available commercially. This would be a potential loophole. Straight WVO would be a potential exemption, under my state law, too, becase it is not *commercially available* as motor fuel. The term, "commercial", implies "commerce", as in buy and sell, not what someone gives you for free as trash. This could be a potential loophole.
The tax applies to "petroleum products", and biodiesel is NOT a petroleum product; HOWEVER, the legal definition of "petroleum product" in the state law is *anything* that can be used as fuel in a motor vehicle, and THAT would include biodiesel even though it is not technically a petroleum product.
The fuel distributor is the one who must collect the taxes (in my state), and this would be you (if you consider that the WVO is the "raw" product, and not usable until you filter/crack it into a suable product.) You are also the manufacturer, or refiner, and there are laws that apply to the refining of "petroleum products" that you should check out. In my state, where the manufacurer is the distributor, the manufacturer has to report inventory information and collect taxes, etc.
Check your state laws. There may be "alternative fuel" exemptions or reductions for alernative fuels.
Or just make your biodiesel tank look like a blackwater tank. Glue a dummy drain system on it and hde the linkage to the fuel line. As long as you don't put a big sign on the bus saying "I use WVO for free and don't pay road taxes on it!", probably no one will ever know. If you get pulled by teh cops on the highway just switch back over to diesel and idle the engine really fast for a minute or two.
Eric von Kleist is offline   Reply With Quote
Old 04-28-2004, 01:21 PM   #26
Year: 1985
Rated Cap: 60
I just looked up some information on the spot prices for vegetable oils.
Interestingly (if you could buy in bulk quantity), SVO is price competetive with diesel. 27cents a pound for refined soybean oil is about $1.89 per gallon.
Anybody live near a SVO oil processing plant?
LATE SPOT PRICES
CRUDE VEGETABLE OILS *
Coconut oil, t.l., N. Y. lb. 26c
Corn oil, Midwest lb. 29c
Cottonseed oil, West Texas lb. 50c
Linseed oil, Minneapolis lb. 41c
Peanut oil, Southeast (rest.) lb. 45c
Soybean oil, Decatur, Ill. lb. 22c
REFINED VEGETABLE OILS
Coconut oil, t.w., N. Y. lb. 31.25c
Corn, jumbo tanks, N. Y. lb. 38c
Palm oil, N.J. lb. 31.75c
Peanut oil, jumbo tanks, N.Y. lb. 55c
Soybean salad oil, N.Y. lb. 27.11c
Old 04-28-2004, 03:37 PM   #27
lapeer20m's Avatar
i started with an oil filter to clean the material. It seemed most logical, and i had a few new ones around.
Interestingly enough...................
In my research, i read that oil filters have a special valve inside that opens to allow oil to pass through after the filter gets plugged up. This allows an engine to never be starved for oil.....This also allows wvo to not be filtered once it's filled the oil filter with contaminates.
Old 04-29-2004, 04:44 PM   #28
lapeer20m's Avatar
I just can't leave well enough alone !
My system works, but it takes a long time to switch from diesel to veggie. It takes about 7-10 miles of driving before there is enough heat to make the switch. Diesel's just don't produce much heat compared to a gas engine.
I've thought of an idea that would allow me to switch over almost instantly. Just before the oil goes into the fuel pump, i'm going to install a deep fat fryer (The Fry Daddy) It holds about a half a gallon of veggie oil. The fryer after some modification will be sealed with a steel lid. The lid will have two "ports" and an engine temp probe that allows the driver to see the temp of the oil in the appliance. This will just simply be a component of the veggie oil fuel system. There will be a line coming in from the veggie tank, and one going out to the injection pump. The plan is to plug in the deep fryer about 5 minutes before starting the rig. Once the electricity heats the oil up to 150 degrees or so , unplug the fry daddy, and start the bus on diesel. After a minute or so, i should be able to switch to my prewarmed veggie oil. By the time the engine burns the 1/2 gallon of preheated veggie oil, it should be generating sufficient heat to warm the remaining veggie oil utilizing engine coolant.
Soon i'll try to post drawings and photo's
Old 05-02-2004, 06:39 PM   #29
lapeer20m's Avatar
Today i purchased a 110 volt water pump to filter the oil. I had been borrowing the 12 volt pump that feeds the injection pump whenever i needed to filter more oil. This was inconvenient to say the least. Here's a photo of the water filter i'm using to filter the oil.
I built a floating strainer for the suction end. After filtering the oil through a water filter, it goes directly into the veggie tank on the bus. My first test batch was at 110 degrees. Next i went right to the veggie oil container behind one of the local restaurants. They have a really clean supply of waste veggie oil. With the clear filter housing, i can monitor the oil to make sure there isn't water or other contaminates noticable to the eye. The oil was maybe 50 degrees. I passed 25 gallons through one filter, but the oil flowed way slower than the 110 degree test batch. I don't think it is necessary it is to heat it prior to filtering, but it would make the job quicker. When summer finally gets here, the oil should flow a lot better.[/img]
Old 05-02-2004, 06:56 PM   #30
lapeer20m's Avatar
Had a bit of a good adventure today on my way home from picking up a tank of fuel at the restaurant.
I was cruising through town, on the busiest road in the county, M 24. I decided to switch from diesel to veggie. After about a quarter mile, the bus started to die. Looking down i instantly realized I had forgotten to turn on the 12 volt fuel pump. Fearing that it was too late, i switched on the pump, and opened the valve for the diesel hoping to not stall the engine. The engine died, but i was still cruising about 30 mph. The drivetrain kept the engien spinning. I was sure she'd come back to life at any second! She didn't. I started looking for a place to pull off, but there's a curb on the edge of the road. The bus won't fit in most of the driveways along that stretch. I was able to coast to a side street. I got off of the main highway, but completely blocked the side road. UGGGGGG! I turned the key, trying to restart the engine while i was coasting down, but to no avail. Quickly i grabbed my 3/4 inch wrench, opend the hood, and cracked the line going to the injector for cylinder # 6. Then i climbed in the bus and turned the key. She sputtered, then died. I turned the key again, and she fired. With the hood still tilted forward, i drove the bus to a nearby parking lot and tightened the nut for the injector.
The rest of the ride home was uneventful.
A month ago, i didnt' have any idea how to bleed injectors!
What works to start a cold diesel engine?? frank-id Everything Else | General Skoolie Discussions 12 02-03-2017 07:15 PM
biodiesel kimberlin Short-Bus Conversion Projects 1 09-08-2013 05:22 PM
Plan in works to fix 'Electric Kool-Aid Acid' bus lornaschinske School Bus News 0 03-16-2013 11:25 AM
Bus ad works frank-id Everything Else | General Skoolie Discussions 3 02-16-2011 01:02 PM
Biodiesel Kit - Has anybody seen anything like this? odyssess Veggie Oil | WVO | Biodiesel | SVO 1 05-22-2008 10:48 AM
