Old 04-18-2004, 11:50 AM   #1
A Biodiesel kit that works
http://ww2.green-trust.org:8383/2000/bi ... efault.htm
These guys are using a skoolie to run with vegetable oil..and it's a working, practical model.
David is offline   Reply With Quote
Old 04-18-2004, 11:49 PM   #2
lapeer20m's Avatar
Let me preface this by saying I know almost nothing about injector pumps and diesel engines !
I've thought it through, and this week if all goes well, i plan to have the bus running on vegetable oil. I plan to first use a crude system to prove to myself that it's feasable before i do a complete install.
In looking at the diagram for the system sold above i have one major concern. The return line from the pump to the tank makes a "T" and is connected back to the supply line. If this works so well, how come the manufacturer created the return line? There has to be a good reason or when the bus was built, they would not have installed the 10 feet of tubing that makes up the return line. I'm concerned this could damage the injector pump.
The rest of the system looks simple enough. I'll do my research and development using SVO initially. IF all goes well, i'll begin the process of finding waste vegetable oil and leaving behind the smell of french fries everywhere i go.
I've found conflicting reports on the net as to how damaging vegetable oil can be. I've talked to a few mechanics, and they all seem to think that vegetable oil should be better for a diesel engine than diesel fuel.
Old 04-19-2004, 12:19 AM   #3
What ever happened to Ron Morrsion? He was running his but on veggy oil. He used to be a member of the yahoo group until arky kicked him off for saying a diesel bus is better. He has been running all over the country on veggy oli. I would talk to him about his experiences if anybody can find him.
busone is offline   Reply With Quote
Old 04-19-2004, 01:08 AM   #4
Steve's Avatar
I have his email, I'll send him a message inviting him to share his knowledge
Old 04-20-2004, 05:47 PM   #5
lapeer20m's Avatar
photos soon to come!
Today i got my bus running on straight vegetable oil. I'm in the research and development state right now, but it was incredible to hear her run on something other than diesel fuel.
I'll keep plugging away at it till a get a system that works well.
My intent is to use filtered waste vegetable oil.
Old 04-20-2004, 07:29 PM   #6
lapeer20m's Avatar
Today i heard something for the first time ever. One of those sounds that breaks the cardinal law of diesel ownership. I heard my diesel engine run out of fuel. UGGGGGGGGG. The positive thing is that I learned how to bleed injectors!!
I worked a solid 12 hours on the project today. I don't have a complete system yet. Here is what i have so far: I have 2 separate fuel circuits, each can be turned on/off with its respective 1/4 turn valve. One circuit is the original diesel fuel tank, the second is the line i'm using for the vegetable oil.
I haven't connected the oil reservoir system into the coolant system yet. To heat the oil I've very appropriately been using a handy kitchen appliance "The Fry Daddy" deep fat fryer to heat my oil. Obviously this is just temporary. I've just been running the engine while the bus is stationary. It's a very crude setup so far.
After using all of my available SVO, i decided rather than buying more, i'd venture off to one of the local restaurants to see about getting some WVO. They were just getting ready to empty the fryers when i walked in, perfect timing! They offered me 100 gallons or so they had out back, but i just took 5 gallons for the time being. I filtered it with a 12volt pump and a hydrolic oil filter. It still looked pretty dark after i filtered it several times, but it seemed to run great in the Ford 6.6 Liter diesel.
How exciting. Free fuel !
Tomorrow i'd like to mount the wvo tank and run all the coolant lines ect. I can't wait to take it for a drive utilizing my WVO.
Old 04-20-2004, 07:57 PM   #7
Steve's Avatar
Your making the conversion process sound easy
Old 04-20-2004, 08:36 PM   #8
lapeer20m's Avatar
it is easy ! How come more people don't do this?? In the past three days i quadroupled the knowlege i have about a diesel engine. I still know nothing!
The majority of the project is done using flexible copper tubing and small 1/4" pipe fittings/valves. So far i've spent approx $40.00
Nearly every part I used for the conversion is readily availabe at home depot. I plan to use a plastic 35 gallon drum for the wvo tank. The junk yard should be able to provide the inexpensive heater core i need to heat the oil. Wal-mart sells the engine temp gage that will tell me when it's time to switch over from diesel to vegie oil.
When filtering the oil prior to putting it in the tank, I first tried to poor the liquid through a large heavy duty coffee filter. Do you have any idea how long it takes veggie oil to flow through a cofee filter?? I decided i was far to imatient for that! Next I tried to use a cheap 12 volt bilge pump to move the oil through a hydrolic oil filter, but it didn't have the pressure. Luckily i have a 12 volt 40 psi pump laying around. I simply connected the pump to a garden hose then found a pipe to screw into the center of a hydrolic oil filter. The garden hose was then attached to the filter with a hose clamp. The pump is made for water, but since it was free, i'll see how long it lasts pumping oil. Lots of lubrication !
I only went to one restaurant to find the waste oil. It's amazing how easy it is to find WVO.
How exciting ! A huge smile has been on my face all day.
Old 04-20-2004, 11:31 PM   #9
I am really glad to hear how well it worked, that is great news. When I get a bus I want to try to run it on WVO. A lot of people say it is better than diesel fuel, of course the price is the best part. I really want an old diesel car or truck to run on veggy oil. The price of fuel is killing me as it is with a little pickup. I hate to think what it would cost with a bus. Keep us posted on how it goes. I wish I lived near by I would love to help out and learn something.
Old 04-21-2004, 08:44 AM   #10
Has anybody tried using the commercially available biodiesel - usually soy oil that has been worked over to run as diesel?
Here's a map of the US showing the locations of commercially available biodiesel.
http://www.biodiesel.org/buyingbiodiese ... fault.shtm
When I get my bus (or bookmobile) I hope to run on biodiesel - although WVO sounds awfully good - you can't beat free!
Paul
PRyberg is offline   Reply With Quote
What works to start a cold diesel engine?? frank-id Everything Else | General Skoolie Discussions 12 02-03-2017 07:15 PM
biodiesel kimberlin Short-Bus Conversion Projects 1 09-08-2013 05:22 PM
Plan in works to fix 'Electric Kool-Aid Acid' bus lornaschinske School Bus News 0 03-16-2013 11:25 AM
Bus ad works frank-id Everything Else | General Skoolie Discussions 3 02-16-2011 01:02 PM
Biodiesel Kit - Has anybody seen anything like this? odyssess Veggie Oil | WVO | Biodiesel | SVO 1 05-22-2008 10:48 AM
