Old 05-14-2009, 12:08 PM   #1
Coachwork: blue bird
Chassis: p30
Engine: chevy 6.2 diesel
Rated Cap: 30
Adding WVO to diesel
Hey I heard that you can add up to 40% well filtered wvo to your diesel tank without ant mods at all. True/False?
canon is offline   Reply With Quote
Old 05-14-2009, 05:11 PM   #2
recycler's Avatar
Year: 86
Coachwork: Thomas saf-t-liner
Rated Cap: 40
Re: Adding WVO to diesel
TRUE!.......And even more once the tank has begun to re-circulate thus heating the fuel, especially in HOT climate areas. But it will run BETTER if the oil is at a optimum temperature close to it's flashpoint. Say, around 170 degrees........just like the coolant that is circulating. RECYCLER
recycler is offline   Reply With Quote
Old 05-14-2009, 06:10 PM   #3
Jerry Campbell's Avatar
Year: 1975
Engine: DD 6-71N
I really don't know but I've heard that only on certain types if injection systems can you blend wvo and diesel.
I'm saying this so you can check it out to see if yours is the right type. I would ask on the oil forums.
Running WVO is cheat only if you don't screw up your motor.
Be sure to let us know what you find out.
Jerry
Jerry Campbell is offline   Reply With Quote
Old 05-16-2009, 09:33 AM   #4
recycler's Avatar
Year: 86
Rated Cap: 40
True to the fact that the newer the engine the more it has been modified to run diesel smoother. This means that the injector ports are smaller and possibly made of alloys that can fuse under the increased heat of burning WVO. There are also sensor problems that might arise if the bus is newer. These can be overidden or replaced at a cost. Tell me what you are or are planning on running for your rig and I could answer more accurately for your needs canon. Pressure guages? Will you be running through the entire tank or partially and then parking it where it gets cold? Pusher vs. conventional?
Adding an auxiliary air tank? Hex Conversion General Discussions 1 03-15-2011 02:33 PM
Adding gasoline to diesel fuel... Not good frank-id Everything Else | General Skoolie Discussions 7 02-02-2011 06:48 AM
Adding a tach to a diesel... NewSkewlHauler Conversion General Discussions 3 01-09-2010 12:50 PM
Adding a bed on the front of the bus Kirbystud Conversion General Discussions 2 08-14-2009 03:04 PM
Adding 3-4 MPG adding ounces of Acetone to your fuel, read. Gyva Everything Else | General Skoolie Discussions 2 02-27-2007 05:00 PM
