Old 03-14-2007, 08:37 PM   #1
mike's Avatar
Send a message via AIM to mike
Aux fuel pump?
I installed a 60 gal fuel tank just to the rear of the factory set up on my international 1988 dt360, what type of pusher pump should I by? do I really need to heat the oil in the tank during the summer weather only, I have installed a aux factory filter before the gate valves along with a home made coolant heater going both ways in the tank lines , I noticed a lack of coolant flowing at idle, is there a pump i could use to help move it along at idle?
mike is offline   Reply With Quote
Old 03-18-2007, 09:48 AM   #2
Re: Aux fuel pump?
Check the temp not the flow at idle, does the lines temp drop if so how much? I dont see it taking that many BTU's to heat what your heating.
hoser is offline   Reply With Quote
Bleed the fuel lines or prime the pump? She won't start! the_experience03 Mechanical and Drivetrains 15 01-22-2017 08:02 PM
Fuel Pump For Generator kc_4_jc Conversion General Discussions 2 09-29-2011 10:26 PM
water pump gbstewart Plumbing, Water and Waste 5 11-11-2010 03:41 PM
TRX 350 Fuel Pump the_experience03 Everything Else | General Skoolie Discussions 2 05-28-2009 09:34 PM
Water Pump Help FelixM Conversion Tutorials and How-to's 4 04-10-2009 09:32 AM
