Old 09-29-2008, 10:46 PM   #1
Year: 1985
Coachwork: GMC
Chassis: Blue Bird School
Engine: Detroit 8.2T Turbo Diesel
Detroit 8.2T Turbo Diesel Blue Bird
So how does the biofuel work for this rig? would i add another tank for the oil? can i just put straight grease/oil form the fryer in the tank or does it need to be altered? how much mpg will it improve? thanks for any input
kl
SKIBUSENTRPNR is offline   Reply With Quote
Old 09-30-2008, 02:50 PM   #2
SoulFire's Avatar
Year: 1979
Chassis: Super Coach
Engine: Detroit 6L-71 Turbo
Re: Detroit 8.2T Turbo Diesel Blue Bird
If you want to run it on biodiesel, you can just put it into the diesel tank and run it...depending on the year of your engine, you might need to change the fuel hoses as biodiesel often corrodes older rubber hoses and eventually creates leaks...viton hoses are the best for biodiesel.
If you want to run veggie oil, you have to add a second tank somewhere, splice a second hose into the diesel fuel line, before the fuel pump. You need a electronic valve switch there to switch from diesel to veggie once the engine is up to temp, then to switch back to diesel before you turn the engine off in order to clean the injectors.
There's a LOT of information all over the net for veggie conversion...just google it. Normally veggie get's equal or worse mileage than diesel...but it's free.
SoulFire is offline   Reply With Quote
Old 10-05-2008, 03:34 AM   #3
Year: 1985
Coachwork: GMC
does biodeisel do okay in the cold winters?
thank you for your time
kl
No start - Detroit Diesel 6.2L non turbo HELP! frank-id Detroit Diesel Drivetrain 15 01-29-2011 06:59 PM
WANTED: Diesel, Blue bird or Thomas agodfrey Classifieds | Buy, Sell, Swap 2 08-12-2010 06:42 PM
Detroit 8.2T Turbo Diesel Blue Bird School Bus SKIBUSENTRPNR Conversion General Discussions 30 10-06-2008 10:49 PM
Detroit 8.2T Turbo Diesel Blue Bird SKIBUSENTRPNR Veggie Oil | WVO | Biodiesel | SVO 0 09-29-2008 06:46 PM
Wanted: Detroit Diesel Turbo TV8101 or TV8102 TonyV Classifieds | Buy, Sell, Swap 2 12-09-2005 02:01 AM
