Old 03-10-2011, 11:02 AM   #1
lornaschinske's Avatar
Rated Cap: 89
Re: DSE fuel
If you simply read or search this forum for the info, you will find it. I think a few are doing it. but the availability of the oil is the problem. We have a food cart (that's how we live) and if we used a fryer, we would be doing a waste oil tank on the bus. As it is, we don't and getting the oil new or used is a PITA. Especially when you are traveling.
A similar question was asked just a couple days ago. That person didn't get many answers either. Like I said, you newer folks need to learn to search and read not just ask. Most of the "newbie" questions have already been asked and answered.... multiple times. Get's tiring answering the same questions over and over.
Fulltime since 2006
Old 04-19-2011, 10:49 AM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: DSE fuel
Originally Posted by mikemounlio
My question is.
Do you guys think it is a good idea to run a diesel bus on just an oil/chem formula? .
The bus may run fine in warm weather depending on the type of engine (which makes a big difference - you should research this before buying a bus), but in the long run it may screw up the engine. So don't be deceived by short-term success. It takes a while for veg oil to screw up your engine, but it will if you are using it improperly. I am highly suspicious of magic fluids you mix with the oil and just run it like that. Most WVO/SVO experts will tell you to spend the time and money on a setup that heats the oil to at least 160F before it hits the injectors. Trying to thin SVO with chemicals rather than heat may introduce fluids into the engine that may cause harm in the long term. Before doing such a thing I would want to hear VERIFIED long-term success stories.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 05-03-2011, 11:59 AM   #3
Re: DSE fuel
If DSE you mean Diesel Secret or something like that then don't get scammed. There's a reason why people that devote their lives to biofuel development will laugh at things like this.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
What kind of fuel are you using? Steve Conversion General Discussions 70 06-10-2019 10:03 PM
The smell of fuel... Henukaw Mechanical and Drivetrains 7 10-29-2013 06:38 PM
Got Fuel? I don't lapeer20m Detroit Diesel Drivetrain 13 06-24-2011 10:58 AM
Fuel Mileage, what do you get thechandler Mechanical and Drivetrains 2 03-25-2010 12:09 AM
If you run the fuel tank dry newbusser Conversion General Discussions 4 05-01-2009 10:08 PM
