Old 12-30-2015, 06:41 PM   #11
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
60 psi? I have no extra pump on my 7.3 with zero problems. The running pressure on the engine is only 40 psi.
If you need 60 psi to move oil from the tank, theres something wrong with the oil.
Old 12-31-2015, 11:19 AM   #12
For a 2000 7.3 the inline pump is 60 psi, I am living in CANADA, not sure if that makes a difference. The stock pump isn't rated for any resistance, the cold is a challenge, I've got more heaters than you can shake a stick at, but I found that adding the veggie specific pump made all the difference, full horse power and no more dead pumps, the bosch pump in my new bus is much more expensive to fix or replace so I wanna do it right the first time.
does anyone know the amount of pressure the pump in a 92 b600 6.6 operates at
Knomadicknowledge is offline   Reply With Quote
Just Right Bus: 1991 Ford Thomas School Bus Conversion kellyetross Skoolie Conversion Projects 12 02-15-2017 10:51 AM
Ford E350 Conversion - RV Regulations?? Luna_Ulta Conversion General Discussions 4 09-03-2014 10:23 PM
'87 Detroit Diesel 8.2L Ford B700 conversion -- help! caster Veggie Oil | WVO | Biodiesel | SVO 0 07-18-2014 10:37 AM
1994 Ford E-350 Shuttle Bus Conversion Seeria Short-Bus Conversion Projects 54 03-05-2013 02:31 PM
1981 Ford school bus camper conversion Steve Classifieds | Buy, Sell, Swap 0 08-08-2004 09:37 PM
