Old 08-25-2008, 01:51 PM   #1
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Helper/Priming pump question ...
For those of you who have additional pumps in your fuel lines, WVO or diesel, what sort of flow rate do you go for so that you don't overwhelm the IP? Are there 'adjustable' electonic pumps out there that I'm just missing?
Also, any suggestions as to makes/models/types of pumps for this would be great!
Thanks!
Hex is offline   Reply With Quote
Seat removal tip if you don't have a helper Butnerbus Short-Bus Conversion Projects 9 02-04-2013 10:41 AM
Air helper springs Stuff Conversion General Discussions 0 08-31-2011 06:03 PM
macerator pump gbstewart Plumbing, Water and Waste 2 02-28-2011 11:49 AM
Fresh water pump question BUSBOZO Conversion General Discussions 1 03-22-2010 12:37 PM
Use of Cummins 5.9 manual priming pump? Elliot Naess Everything Else | General Skoolie Discussions 6 05-17-2007 10:16 AM
