Old 05-06-2010, 10:47 PM   #1
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
My WVO conversion
I'm 98% finished with what I've had in my brain for a while. Where the heck do you put a system in a van-based shortie? The answer was underneath.
My tank pick up -pex line for the fuel-gas line for the water. Iv'e seen them all coiled up for the heat. I'm not worried-my tank is only 1 foot away from the filter.
My tank doesn't have any baffles-and I was worried about picking up fuel once it got low. So I made up this little chamber (out of a just out of a plastic jug. a couple of trapdoor might hold enuff to keep it from sucking air when low. (Idea taken from roadrace engines i build at work-they have baffled oil pans like this.
I made a steel plate and mounted some 100 lb drawer tracks.
I made sure everything would fit and be servicible if needed. Greasecar solinoids-generic remote oil filter mounts (for a Ford-3/4" X16 thread) The heater section is an oil cooler from a ford pick up. I had to make up an adapter to make it work.
I wanted to be able to shut off the coolant-just in case.
The hose is "push lock" from Mcmaster Carr. hi heat-hi press-strong stuff. Actually cheap too-only $1.20 a foot. Color coded just to be fancy. Happyness is never having to chase an air leak-or tighten a hose clamp.
Heres what it like retacted. The fuel hose bends nice-the heater hose I had to be a bit more careful to avoid kinks.
I pitched the tank down a bit towards the front to be sure the pick up stays under fuel. Next up is make the cover and a trap door..
Old 05-13-2010, 10:26 AM   #2
crazycal's Avatar
Re: My WVO conversion
If you are using an oil filter for wvo, be careful. Most oil filters have a bypass if they get clogged. Better to run an engine on dirty oil than burn it up with clean oil that can't get past a plugged filter. If the same thing happens with wvo, all that crud with dump right into your IP resulting in huge loss of $$$$$$$$$$$$$$$$.
Nice looking setup by the way.
I'm hungry!
You Gotta Let Me Fly
Old 05-13-2010, 11:15 AM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Oh no--its fuel filters--I'm just using what was originally made as an oil cooler to provide hot water to heat up the wvo. (wix 3281? i believe?) It was the largest 3/4x16 thread fuel filter I could find . Original use is Fiat Chambers equipment + Iveco trucks.
Old 05-13-2010, 11:36 AM   #4
crazycal's Avatar
I will be using Racors like this. I have bought a number over the years for less than $100 each. Replacement filter run about $6 by the case and you can see what's going on through the clear bowl.
I'm hungry!
Old 05-13-2010, 11:57 AM   #5
crazycal's Avatar
What's up with the DOT numbers on the side. It's not still a bus is it? Unless you need to have those on there, I would take them off. Here in CA, CHP can pull you over whenever they feel like it if you have numbers like that on your rig. Commercial vehicles have a different set of rules.
I'm hungry!
Old 07-17-2011, 01:11 PM   #6
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Sorry-just noticed this post. Homemade system-Greasecar valves. Alot has been said of Frybrid-most concerning hi price+extreme long wait for paid for product. I get oil from a couple of small resturants-filtered to 1 micron. Dont even think of converting untill you get a grease supply in place! a 7.3 loves grease. I dont use it in the winter-but did do a 800 mile trip in the upper 30's last november-the large exposed tank didnt help oil temps-but it kept running fine.
Old 07-21-2011, 11:00 PM   #7
rjz5400's Avatar
Chassis: Thomas? Safe-t-liner
Engine: 6bta5.9
this thread is well over a year old, maybe try sending email to OP or asking questions on a move active WVO forum like
BurnVeg
Greasecar
for more general WVO tips and tricks,
rjz5400 is offline   Reply With Quote
Old 07-22-2011, 10:52 AM   #8
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
id love to this to my bus to now that i got it running good lol
