Old 10-01-2008, 12:01 AM   #11
Re: need fuel flow diagram for t444e
it would probably be benificial to order/buy the factory repair manuals for both the chassis and engine so that you know what systems are there and how they are supposed to work
use after market filters/water seperators,RACOR or GOLDENROD are popular brands, for your wvo system, they have removeable transparent bowls with drains that makes checking and serviceing them easy,
Install an electric pump at the tank to push your grease thru the system, it can also be used to bleed/purge air from the lines and filters.
don't forget to run a seperate return line (low pressure) for the wvo to keep from contaminating your diesel tank, it is necessary to circulate fuel thru the system to cool and lubricate the injectors.
try to find a fuel tank switching solenoid/valve that has provisions for both supply and return, NO scratch that you want to switch fuel in and then have time to flush the wvo out of the system before you switch return lines, seperate valves.
good luck and keep us posted
Old 10-01-2008, 10:03 AM   #12
Coachwork: Mid-bus
Chassis: international
Engine: t444e
Rated Cap: 49?
i would love to buy a manual for the engine. any ideas where to find such a thing. Ive been looking for a few weeks now, on and off.
Bungeekord is offline   Reply With Quote
Old 10-01-2008, 10:35 AM   #13
try your local IH Navistar dealer or google
need fuel flow chart for T444E. mereian Veggie Oil | WVO | Biodiesel | SVO 2 10-14-2011 05:56 PM
Direction of Coolant flow in E350 zman18 Veggie Oil | WVO | Biodiesel | SVO 1 08-31-2010 03:32 PM
Problem of flow recycler Veggie Oil | WVO | Biodiesel | SVO 2 11-23-2009 10:10 PM
My fuel system plans, with diagram. The Eggcrate Veggie Oil | WVO | Biodiesel | SVO 1 04-21-2009 05:22 PM
Fuel Flow Logistics...any advice? SoulFire Veggie Oil | WVO | Biodiesel | SVO 0 01-28-2009 02:58 PM
