Old 07-10-2008, 09:48 PM   #1
lapeer20m's Avatar
Re: Onboard filtration systems
i had an onboard filtration system on my veggie bus. i used a 110 volt sump pump to transfer oil from the "grease dumpster" to my "dirty tank". the sump pump had a built in screen that kept any debris from entering the pump...
once onboard, the dirty tank was heated utilizing waste engine heat, then the hot oil was filtered and put into the "clean tank"
from clean tank the oil traveled to the injector pump via a pair of filters.
a centrifuge would be great for cleanign oil.....i was using whole house drinking filters. i found that i could get up to 10 or 20 gallons of oil through a filter before it became clogged......or if i heated the oil i could get over 100 gallons through the same filter.
Old 07-11-2008, 10:56 AM   #2
I used a centrifuge setup for about 2000 gallons of veggie last summer. Centrifuge is the way to go. Pump with a screen into a dirty tank and let centrifuge take care of the rest. Gonna have to run it on 110V. Better than settling cause sometimes you don't have time to settle. No filters less mess (unless you forget to tighten a hose clamp on a pressure line) Def the way to go. Can give more specifics later but now have to run. Good Luck.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 07-22-2008, 10:49 AM   #3
Year: 92
Engine: 6.9
What centrifuge do you use? I would love to see a schematic or photos of any on-board filtration. We are trying to redesign ours.
theVeganBus is offline   Reply With Quote
Old 10-04-2008, 10:46 PM   #4
bus-bro's Avatar
Engine: 3208 na boat anchor
I just did some research on centrifuges. Alfa-Laval (as I recall) has a small unit for yachts, it can be procurred for 115 VAC or 24 VDC. the price is probably more than a bus x 3 (or 4, or 5). Those ones that spin from the oil pressure are not good if you need to seperate some water or lighter particulates.
Old 11-17-2008, 07:27 PM   #5
SoulFire's Avatar
Year: 1979
Chassis: Super Coach
Engine: Detroit 6L-71 Turbo
Hey stickman,
How does your centrifuge work? Does the Carbonate motor power the gear pump head that pushes the veggie through the centrifuge? Do the components you got work well together? I'm thinking about getting the same ones...any tips?
SoulFire is offline   Reply With Quote
Old 11-29-2008, 08:30 PM   #6
In my opinion a centrifuge is the only way to go for onboard filtration. You should run a 110v motor for the pump, I've never tried a 12v but it does require a lot of time to clean the grease. Movement will not affect the operation just make sure the veg doesn't splash out of the tank!
120-volt (only) onboard refrigerator. Abbott Conversion General Discussions 10 09-08-2016 12:25 PM
Free onboard AC units (Seattle, WA) djDK Classifieds | Buy, Sell, Swap 0 11-12-2014 05:10 PM
Leveling systems lornaschinske Conversion General Discussions 0 08-04-2012 10:42 AM
Mobile Filtration and Dewatering - Heating and Settling dlor1 Veggie Oil | WVO | Biodiesel | SVO 0 02-10-2011 09:14 PM
Sewer Systems Steve Conversion Tutorials and How-to's 0 06-16-2004 12:31 PM
