Old 05-12-2009, 08:46 AM   #1
recycler's Avatar
Year: 86
Coachwork: Thomas saf-t-liner
Rated Cap: 40
Overall WVO capacity
Just curious as to how much WVO some people are carrying at any given time. I'm thinking of increasing my "clean" reserve. Currently I travel with a 60gl tank and a few cubits to supplement. For the uninitiated, a cubit is the container that new veg oil comes in......I think it is almost five gallons. I want to increase my distance to 1000 miles before I have to refill. I figure 1000 miles is a pretty darn good trip distance before needing refueling. Who has what on board? RECYCLER
recycler is offline   Reply With Quote
Old 05-12-2009, 09:12 AM   #2
Jerry Campbell's Avatar
Year: 1975
Engine: DD 6-71N
Re: Overall WVO capacity
90 Gallons in the bus and 10 or 15 in the back of my pickup.
I get between 9 and 10 MPG.
Jerry
Jerry Campbell is offline   Reply With Quote
Old 05-12-2009, 10:16 PM   #3
recycler's Avatar
Year: 86
Rated Cap: 40
Did you run 90gallons when you were doing mexico Jerry?
Old 05-13-2009, 09:19 AM   #4
Year: 1975
Engine: DD 6-71N
When we left Oregon we had 105 gallons. Because of a coolant leak, I only burned about 40 gallons on the way down there. While there, I fixed the leak and collected from the palapa resturants on the beach and filled the tank. I left there with 90 gallons. I drove from San Blas to Guaymus on WVO. Everything worked great. It was a great first run on oil.
Jerry
Old 05-14-2009, 10:55 AM   #5
Engine: 7.3L IDI
Rated Cap: 44
I plan on installing dual 140 gallon aluminum round tanks from a freightliner semi in just a few days. That should give me some distance.
The Eggcrate is offline   Reply With Quote
Old 05-14-2009, 05:03 PM   #6
recycler's Avatar
Year: 86
Rated Cap: 40
Nice, how much did you score those for..........free? Thats like a whole road trip for one fill-up! Thats what i'm thinking, fillerup before the trip so you don't have to hunt. WHERE did you score those tanks and are they going underneath? RECYCLER
Old 05-20-2009, 09:50 AM   #7
Engine: 7.3L IDI
Rated Cap: 44
I did indeed get them from free from a trashed freightliner. Last road trip i went on was 7500 miles, so I'll have to fill up when I get to the west coast again, but its no problem. I will be putting these things under the bus. At 24 inches tall, they'll be quite low, but still higher than an RV I think. The door frame for the bus and the front axle thing comes down that far, so I just have to worried about very poorly graded areas. My bus should still be able to go over even the largest speed bumps. I will put two steel bars below the tanks and to the sides so that they will scrap first, indicating a bad situation before I hit a tank. I have to create an adapter plate to mount the tank brackets to the bus frame as the holes do not line up, but this shouldn't be a problem.
DT 360 oil capacity SeanF Conversion General Discussions 9 07-12-2021 02:42 PM
Whats the oil capacity of my bus? Spoon International | Navistar Drivetrain 7 03-18-2019 08:24 AM
Capacity and Bus Dimensions Seeria Conversion General Discussions 7 08-29-2017 05:22 PM
Tank capacity? porkchopsandwiches Plumbing, Water and Waste 3 12-12-2013 04:17 PM
Tow capacity of a school bus? stonestatue Everything Else | General Skoolie Discussions 3 09-15-2012 12:21 PM
