Old 08-26-2010, 09:26 AM   #21
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Pex as heat exchanger?
I know this thread is fairly old, but I'll chime in for the sake of posterity . The Greasecar WVO conversion kits come standard with pex hose-in-hose to supply fuel sheathed in coolant-filled heater hose. I've had this system mounted on my Mercedes 300D for the past 3 years and probably at least 30K-40K miles, and have not had any problems. The heat exchanger in the tank is copper, but this gets less heat than the pex. I'm sure the copper is a better heat exchanger, but if you don't need that much heat in a particular part of your system, the pex holds up just fine. Even the brass compression fittings that hold it in place are still holding fine.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 05-03-2011, 11:54 AM   #22
So 4 years and 40K miles later the pex is still runnin in my ghetto grease tank. Going to upgrade this summer to a proper tank setup but hey it got me this far.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 05-13-2011, 08:11 PM   #23
bus-bro's Avatar
Engine: 3208 na boat anchor
Don't think the pex will do well in oil, especially hot oil. Flat plate heat exchangers aren't that bad dollar wise. Copper would work, but vibration can cause it to work harden and crack. Pex might not be compatable with all antifreezes.
Old 06-18-2011, 11:30 AM   #24
Engine: 8.2L Detroit Diesel
Is there any reason why you can't use a jacketed aluminum line? This would be really easy to weld up and would transfer heat very efficiently, and the cost of materials would be minimal. So long as you use a have enough wall thickness and you plan to replace every 5 years or so. I can't imagine you would have terrible problems with corrosion. Is there something that I am missing?
Also has anybody tried heating electrically?
Graham
http://www.intrepidequipment.com Intrepid Recumbent Handcycle Specialists, San Diego, CA
grampsbutler is offline   Reply With Quote
Vormax heat exchanger FlyingPig Veggie Oil | WVO | Biodiesel | SVO 2 09-25-2014 08:02 PM
heat vanpeoplx2 Heating, Cooling and Appliances 10 01-14-2011 07:34 AM
What should I use for heat? Diesel Dan Conversion General Discussions 2 10-10-2010 07:54 PM
no heat mfrederick Skoolie Conversion Projects 6 01-11-2010 09:05 PM
heat exchanger and two seats needed ! abdabbs Classifieds | Buy, Sell, Swap 8 01-27-2005 07:24 PM
