Old 11-14-2008, 09:06 AM   #1
phillbus914's Avatar
Re: Powering a bus with water...
check out this post... viewtopic.php?f=6&t=3199&start=0&st=0&sk=t&sd=a
I don't think you can completely run on just hydrogen without some major modifications... When using gasoline you're still feeding the correct ratio of fuel/air to the engine - and adding hydrogen in the air intake (similar to adding nitrous oxide to gain HP) With fuel when you step on the throttle you feed more fuel to the engine... with HHO isn't there just a generator feeding the same amount of hydrogen to the engine at idle and at higher RPM's?
I'm no expert on HHO but that's one major point you'd need to address.
Are you seeing significant mileage increase? Smitty on here tried it, but I don't think he seen very good results and he gave up on it. Made me very skeptical of HHO add ons....
And now that gas is less than $2 a gallon (diesel around $3) I haven't heard much buzz on it.
My Old Bus :(
Old 11-29-2008, 08:41 PM   #2
Yeah I'd be really interested to know how it works out. I've heard of good results before but never out of experience. My problem up here is the water freezing.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 11-29-2008, 10:38 PM   #3
I don't know how this got posted 2 times.. somehow I answered both of em the same... wierd...
anyway check out this link viewtopic.php?t=3668
My Old Bus :(
Old 12-08-2008, 12:09 PM   #4
TikiBus's Avatar
Year: 92
Coachwork: Amtran Genesis
Engine: International DT466
I wish I knew more about this, but I am still wrapping my mind around wvo. How do you go from place to place while brewing? doesnt it stir up sediment. Maybe you dont, a couple weeks here and youve got bottled beer...enough fuel to get you to another brewspot? Please give the specs of your setup and how the brewing process is different in a bus. Thanks!
TikiBus is offline   Reply With Quote
help on black water and grey water hookups heath692 Plumbing, Water and Waste 8 04-18-2015 05:57 PM
water tank and quality of water bansil Plumbing, Water and Waste 12 03-01-2012 09:40 AM
Saving Water/Water Reduction Redbear Conversion General Discussions 9 10-06-2009 02:37 AM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
Powering off inverter while in motion windsurf17 Conversion General Discussions 14 07-31-2008 08:20 AM
