Old 06-03-2008, 06:25 PM   #1
Train-train's Avatar
Transfer pump for my oil
I am beginning to see a need for a transfer pump to divide my oil into smaller quantiles. I have found a clear water pump offered by Harbor Freight that is very cheap. Do any of you have any experience with this pump and will it work for what i want it to do?
Thanks!
Train-train is offline   Reply With Quote
Old 06-04-2008, 12:54 AM   #2
lapeer20m's Avatar
Re: Transfer pump for my oil
for moving large quantities of oil, i've had really good luck with a 110 volt submersible sump pump with inch and a quarter hose on it. Moves 50 gallons of veggie in just a few minutes.
for smaller quantities i like to use a 12volt diaphragm pump available from tractor supply for about 80 bucks. Moves just a couple of gallons per minute, but at 40 psi or so, so it's good at pushing oil through filters. looks like this:
there is also a self priming rotary pump that tsc sells, but they seem to have a relatively high failure rate with veggie...but i do find this one to be a good engine coolant pump, even though the pump clearly sais it's not to be used with hot liquids. I had one that ran for hundreds and hundreds of hours circulating coolant. looks like this:
Driveline Gear box/transfer case? JoeA Conversion Tutorials and How-to's 18 06-01-2021 09:45 AM
power transfer relay ol trunt Classifieds | Buy, Sell, Swap 9 07-21-2012 09:26 AM
Transfer Switch dead; Burned relay; Replace it? Redbear Conversion General Discussions 1 03-04-2009 02:59 PM
Transfer switch reprobate Conversion Tutorials and How-to's 5 12-11-2007 11:27 PM
oregon title transfer westport_wayne Titles, Insurance, Registration and Money Matters 5 04-11-2006 01:19 PM
