Old 04-27-2009, 06:49 PM   #1
SoulFire's Avatar
Year: 1979
Chassis: Super Coach
Engine: Detroit 6L-71 Turbo
Veggie Fuel Line IDeas?
I'm wondering what size (Inside Diameter) fuel line I should be running for my veggie system in a 1979 Crown Supercoach with a 1978 Detroit Diesel 6L-71Turbo. The stock, diesel fuel line has a 1/2" inside diameter. I don't want to restrict fuel flow when I switch over to veggie but the fittings on my filter are like, 5/16" ID. Has anyone had any problems with reducing the diameter of their veggie line? Give me some info. What size is your diesel fuel line compared to your veggie line?
Thanks!
SoulFire is offline   Reply With Quote
Old 04-27-2009, 08:36 PM   #2
recycler's Avatar
Year: 86
Coachwork: Thomas saf-t-liner
Rated Cap: 40
Re: Veggie Fuel Line IDeas?
Mines an International and has 3/8 so I stayed with the 3/8. Maybe try asking at a local bus barn and see if someone can tell you if that will cause constriction.
recycler is offline   Reply With Quote
Old 04-27-2009, 09:00 PM   #3
SoulFire's Avatar
Year: 1979
EVERYTHING is 3/8?? All your ports for filter and pump and all?
Old 04-28-2009, 08:23 AM   #4
recycler's Avatar
Year: 86
Rated Cap: 40
Well, almost true. The ports on my heated racor filter are 1/2", but I put 1/2"to 3/8" hose barbs on it. I figured with my self-regulating aux. fuel pump that I wouldn't have any problems and I haven't.(knocks on wooden object) I just wanted to have a simpler set of extra parts. I think someone posted somewhere and gave meathumbs up at one time or another. RECYCLER
PEX as fuel line? sojourner Mechanical and Drivetrains 6 09-28-2014 03:02 AM
1995 DT466 Fuel line gildorr Mechanical and Drivetrains 5 06-30-2014 10:09 AM
Fuel Line Question White99z Mechanical and Drivetrains 0 05-15-2014 10:16 AM
Veggie Fuel DrJohn Veggie Oil | WVO | Biodiesel | SVO 1 02-10-2011 08:53 PM
Generator Fuel Line Steve Conversion General Discussions 6 01-17-2004 07:43 AM
