Old 10-29-2006, 07:10 PM   #1
needabus's Avatar
Send a message via AIM to needabus
Veggie-oil
I was wondering about Veggie-oil converters, and the possiblity of putting one on or in the back of my bus
When you participate in sporting events, it's not whether you win or lose; it's how drunk you get.
needabus is offline   Reply With Quote
Old 10-29-2006, 10:15 PM   #2
the_experience03's Avatar
By converter are you looking for a filtration system, an aseembly to run veggie oil as a fuel, or a biodiesel refinery?
The filtering can be done onboard although I will tell you from experience that it likely isn't going to be real fast, smells a little, and takes up a lot of space.
If you're looking to run veggie oil as a fuel, just look around. There are a bunch of people running a system on their bus, myself included. Jason (lapeer20m) probably has the most well documented system.
If you're looking to put a biodiesel plant in the back of the bus...well...I would urge you to reconsider. You will still be plagued by the filtering issues, but more importantly, you'd be hauling around lye and methanol, both very dangerous. In fact, I'm not sure what the legality of such would be as both are likely classified as hazardous materials.
Old 10-30-2006, 07:33 AM   #3
lapeer20m's Avatar
here's a couple skoolie.net links:
http://www.skoolie.net/forum/viewtopic. ... idesel+kit
the basic theory of veggie conversion is that any older (mechanically injected) diesel using an inline IP like most skoolies seem to have can run veggie oil as long as you heat and filter the oil before it arrives at the engine.
The best method for heating is using engine coolant to heat your veggie tank. The vehicle must be altered with a 2nd tank just for the veggie. The stock diesel tank is utilized to start the bus and get things warmed up, then the driver can switch over to veggie and away you go.
Old 10-30-2006, 07:20 PM   #4
needabus's Avatar
thanks for the advice guys
Where should I put my Veggie tank? Train-train Alternative Fuels | Electric, Propane, Wood & Biofuels 4 04-27-2009 09:38 PM
veggie kit dlor1 Alternative Fuels | Electric, Propane, Wood & Biofuels 7 07-11-2008 11:01 AM
Can I go Veggie? Train-train Alternative Fuels | Electric, Propane, Wood & Biofuels 8 10-30-2007 10:51 PM
mmm bus veggie bus bewofthe Skoolie Conversion Projects 4 03-18-2007 09:16 AM
How to get veggie oil? davido Alternative Fuels | Electric, Propane, Wood & Biofuels 10 08-21-2006 04:14 AM
