Old 09-17-2006, 10:29 PM   #11
the_experience03's Avatar
That's my understanding too, Jason....as measured on a knockometer (not shitting)
Interestingly enough, octane refers to a hydrocarbon chain not present in gasoline, but gasoline acts like it.....go figure
Old 01-24-2007, 12:10 PM   #12
Ive mixed up to 20% gasoline in with my WVO at times when the oil just wasnt that great of quality but I was stuck in a bind. It works great when you end up with a bunch of crappy hydrogenated oil. Mix about 20% gasoline in, and MIX IT UP REAL GOOD. it will be thin enough to get through your filters now, and wont plug up your system. You also wont lose as much HP.
I notice when Ive run straight hydrogenated oil, my power dropped significantly, and it was a real pain!
ParadigmCrime is offline   Reply With Quote
Old 01-13-2008, 04:07 AM   #13
SD26's Avatar
Coachwork: Goshen
Chassis: E350 Ford
Engine: 7.3 Power Stroke
Rated Cap: 10
Re: Veggie Oil mixed with Gasoline??
Old thread, sorry, but I'm hip deep in all this.
My bus is currently running a hybrid mix. In my approximately 37 gallon tank I have, one gallon of gasoline, two gallons of vegetable oil, and thirty four gallons of regular diesel. This mix is a bit new to me, but my seat of the pants feel is that the engine is running very smoothly, and I should have used more fuel. I need more time on her.
I have disposed of used engine oil in my diesel tank a number of times with no ill effects in tens of thousands of miles now. I even neglected the fuel filter to see if I'd have a problem. I didn't.
I am running a little vegetable oil with my gasoline in my Ford Taurus right now. This will be tank number three. I'm unsure of my results as of yet. Nothing is really impressing me as of yet. It's also cold out too.
SD26 is offline   Reply With Quote
Old 01-13-2008, 08:39 PM   #14
reprobate's Avatar
Let us know SD26, I for one am interested in your results. I know nothing of the veggie conversion side, but want to learn more once I'm done with the inside conversion.
reprobate is offline   Reply With Quote
running both LP and Gasoline in GMC engine captainkf Alternative Fuels | Electric, Propane, Wood Gasification, etc. 4 11-11-2012 07:05 PM
Propane to gasoline conversion northerner GM | Chevrolet Drivetrain 6 09-02-2012 11:09 AM
IH MV404 gasoline engine misfire -- help! Elliot Naess Conversion General Discussions 29 11-02-2006 06:13 PM
International 404, 6.9 and 392 gasoline engines? Elliot Naess Conversion General Discussions 2 02-04-2006 03:48 PM
Exhaust brake for gasoline engines rabiznick Conversion General Discussions 0 08-07-2005 08:03 AM
