Old 09-25-2014, 03:24 PM   #1
Chassis: Short
Engine: 6.2 Detroit Diesel
Rated Cap: 16
Vormax heat exchanger
I just purchased a 1990 short school bus with a 6.2 detroit diesel engine. i would like to convert it to run WVO. It came with a Vormax Heat exchanger and filter, a model 500fg diesel fuel filter/water separator and a box of extra filters. what do you guys think about these parts?
FlyingPig is offline   Reply With Quote
Old 09-25-2014, 05:10 PM   #2
crazycal's Avatar
Re: Vormax heat exchanger
I think plant drive or whatever they call themselves sold those. They used them on single tank installs.
I'm hungry!
You Gotta Let Me Fly
Old 09-25-2014, 08:02 PM   #3
Chassis: Short
Rated Cap: 16
i am trying to plan out the full system that i will need in the bus. eventually i want to be able to filter and use wvo on the road. i would like to have a dirty wvo tank that is filtered into a clean tank. From there another heater and filter to the injectors.
i am trying to decide
a) what else i need (pumps filters heaters)
b) in what order i should put them.
if i was building this from scratch i would go
dirty tank, pump, 20 micron, 10 micron, 2 micron filter into the clean tank.
from clean tank, pump, to flat plate heat exhanger to clear inline filter to electric heated lines to injectors.
i am trying to decide if i should use these parts in the first filtration system or from the tank to the engine? i am also worried about finding filters for these parts on the road.
Pex as heat exchanger? dlor1 Veggie Oil | WVO | Biodiesel | SVO 23 06-18-2011 11:30 AM
heat vanpeoplx2 Heating, Cooling and Appliances 10 01-14-2011 07:34 AM
What should I use for heat? Diesel Dan Conversion General Discussions 2 10-10-2010 07:54 PM
no heat mfrederick Skoolie Conversion Projects 6 01-11-2010 09:05 PM
heat exchanger and two seats needed ! abdabbs Classifieds | Buy, Sell, Swap 8 01-27-2005 07:24 PM
