11-26-2005, 10:48 PM
#21
When the time comes I will try a water cooled condenser coil and see how hot it will heat the oil. If that all fails I will have to have a smaller tank that is heated. The idea of 300 gallons of hot oil being splashed on somebody in an accident scares poop out of me. I just don't want to have to pump oil from the large tank to a smaller tank to be heated. I want to go wiht the KISS method.
12-08-2005, 08:14 PM
#22
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Slow Progress
I haven't been able to devote much time to working on this project lately, mostly because of school and work. I have one last exam tomorrow, and then I will have a month off to work on the bus before next semester starts. (Except, I'm going to Buffalo, NY, this weekend for a Mock Trial tournament with my school's Mock Trial team.)
Anyway...what I have been able to do...
Bought diesel tank, pulled it from old truck, painted it and mounts. $50 for tank and $8 for paint.
Bought Pollak 6-port electronic fuel selector valve. $72 (including shipping).
Bought electronic fuel pump from NAPA. 32 GPH. 1.5 - 4.0 PSI. $32.
Bought new left turn signal from NAPA $42.00 (not WVO related, but I needed one since a pecan limb fell on the bus back in May and knocked the old one off, crushing it).
Bought water heater element for tank. 1500W 120VAC. $8.
Bought thermostat for heater element. $20.
Bought mounting kit for heater element. This is a steel plate that is threaded for the element. It is designed to be a universal mount for water heaters, but I am going to have it welded onto the diesel tank as a permanent mount for the heater element.
I think I still have some Romex wire that I can use to hook up the water heater, but on second thought, I might just buy some of that black extension cord wire, the heavy stuff that people recommend for wiring busses.
What I need to do now with what I have:
Get tank welded.
Install heater element in tank.
Install thermostat on tank.
Mount tank.
Run wires for heater element/thermostat.
Mount pump.
Mount fuel selector. (Location TBD)
Wire fuel selector and mount switch(es) on dash. I may not use the stock switch (DPDT toggle) and use separate switches that will give me greater control over the timing of the switching of the return line.
What I still need to get:
On/Off switch for 120VAC heater. I'm going to mount this on the dash. I'll be using a 120VAC toggle switch for this so it will "fit in" with the rest of the switches on the dash. Estimate: $5.
Stuff to build a heat exchanger for under the hood. May use SS tubing and have one custom welded. Estimate: $5,000,000,000
Stuff to build a heat exchanger for inside the diesel tank. Plan to use 3/8" SS brake line instead of copper. Just too concerned about corrosion of the copper by the WVO. Estimate: $35 for 10' of brake line. $35 for fittings.
Heater hose for various heat exchangers. Will use some synthetic that is resistant to WVO corrosion, not rubber heater hose. Estimate: $50.
Fuel filters for WVO. Going to use 2 household water filters in line: 15 micron and 5 micron. Estimate: $50 for filter housings, filters, and fittings.
12V marine bilge pump with SS pump head for collecting WVO. Estimate: $40 (from Harbor Freight...)
Scavenge tanks of some kind for collecting WVO.
Make a heating tank to heat the WVO and run it through a 30 micron filter prior to putting it into the bus's tank.
Gotta go study espanol for my exam tomorrow!
12-14-2005, 04:32 PM
#23
Year: 1985
Rated Cap: 60
Well, not much progress to date.
Okay, I've made my mind up what I'm going to try. Initially, I was going to run a copper line into the fuel tank as a heat exchanger. Instead, I'm going to use a 4' flexible stainless steel hot water heater hook-up line. With my tank, that will be long enough (when doubled back on itself) to reach down from the top of the tank and run out in an L shape along the bottom of the tank near the fuel pickup line for about 9 inches. That should liquify things enough to get it pumped to the forward heat exchanger, which I have yet to design... For a forward heat exchanger, I'm thinking of wrapping copper tubing around another length of flexible SS hook-up line. I don't forsee any corrosion problems pushing coolant through a copper line, and I don't forsee corrosion problems pushing WVO through an SS line. I just don't like the idea of having the two lines capable of contaminating one another if corrosion occurs. By wrapping the tubing around the steel, and soldering it in place, I hope to avoid problems.
Great...now I'm worried about bi-metallic corrosion. Sheesh... Oh, well, at least the lines won't leak into each other.
Home Depot has high pressure hose that is highly oil/chemical resistant, so that's what I'm going to use for WVO fuel supply/return lines.
Found some SPST toggle switches at Radioshack that will control the 120V hot water heater element.
Stopped and ate dinner at a Chinese restaurant last night just so that I could have a chance to inquire about their used oil. Apparently they use something that is solid at room temp. No thanks!
Trying to figure out where I'm going to put switches on the dash/control panel. I'm going to separately control the fuel selector with 2 switches instead of using the DPDT switch that it came with. Beside each switch I'm going to mount indicator lights -- green for WVO and amber (or blue) for diesel.
Then I'm going to label the switches "Phasers", "Photon Torpedos", "Tractor Beam" and "Anti-Matter Dump"
12-14-2005, 06:12 PM
#24
i think you mentioned you have the 6 port pollock valve and want to control the fuel and return line circuits independant of each other. Even with two separate switches, you cannot control the fuel line and return line indepently. Both fuel and return are either open or closed depending on the positon of the valve. The reason for the crazy switch that comes with the valve is that the two wires that control the valve require the polarity to be reversed for the valve to open or close.
the other item of concern is the bilge pump to move oil....I tried this with a 700 gph bilge pump and it would not pump the oil. It moves water as fast as a garden hose, but refused to pump oil. My bilge pump was plastic, perhaps the stainless one you have will work better.
I use a 110 volt submersable sump pump. It easily runs off of a 700 watt inverter. I bought the pump from home depot for under $100
12-14-2005, 11:54 PM
#25
That stuff at the Chinese restraunt is probably partially hydrogenated vegetable oil. Not any good for fuel or any good to eat.
12-15-2005, 05:39 PM
#26
Year: 1985
Rated Cap: 60
I figured that the restaurant was using a part. hyd. shortening. Years ago we used one called Fry-max at Wendy's. I haven't bought the stop yet. I wanted a 12VDC pump, and may settle for the inverter. That's added expense immediately, but less $ than buying a stop that won't work! I'm going to fool with the valve and see if I can make it work my way. I see what you are saying, but the pump appears to have two separate valves. Via cell - sorry if it sounds terse. Thanks a bunch for the suggestions!
12-22-2005, 08:22 PM
#27
Year: 1985
Rated Cap: 60
Limited computer access compounded by local ice storm power outages....
Lapeer, right after I posted that about the Pollak valve, I got it out and looked at it for the first time since I received it. Of course, it was instantly obvious that you were right about the switching.. It has two valves, but one solenoid. So, I guess I'm stuck with having some WVO in my diesel tank -- unless I put a loopback system on the engine, but I don't want to do that. Oh well, I can just buy a bunch of switches and put them in the control panel with silly labels without hooking them up to anything but indicator lights.
I got the tank cut and welded for $100. Ouch. I'll post pictures soon.
There is a 4.25" x 1.25" slot for the heat exchanger to enter, and a plate with fittings to which the heat exchanger will attach. I drilled holes around the slot and tapped them for machine screws that will hold the plate and fittings to the tank.
(Still trying to get all the metal shavings out of the tank with a magnet on a coathanger.)
The adapter plate is welded in the end of the tank near the bottom, and the water heater element fits in it nicely.
Next I have to assemble the heat exchanger/plate and pressure test it. Then I have to mount it in the tank and then put the tank in its mounts. THEN I have to hold it in position on the frame and see where the mounts need to be located. THEN I have to bolt the tank to the frame while in the mounts, because there is no room to put the mounts on and then add the tank.
I need to get an electronic automotive temperature gauge for the tank. I was going to use a hot water heater thermostat, but that's too much wiring to be hanging on the underside of a bus. I will just use a temp gauge, and turn the water heater element on/off with a switch.
Then my bus will have a tank that is not hooked up to anything. But I will know how hot it is.
I got two home water filter units for filtration, and will mount them in series. One will have a 30-15 micron filter, and the other a 15-5 micron filter. Somewhere I'll add a water filter, too.
Still have to come up with a final (180 degree) heat exchanger. Thinking about running a copper coil above the exhaust header somehow. Not sure about that one, yet.
Then I have to run fuel supply/return lines.
Then I have to run water heater lines for the in-tank heat exchanger.
Hmmm.... what have I left out.
I was supposed to move to the park this weekend, but that's not going to happen until I get this conversion done. Maybe a week????
I made an Xcell spread sheet of how many miles of free fuel I would have to burn before this conversion would pay for itself with diesel at different prices. The spread sheet updates itself each time I add another expense. I'm going to have to drive a lot more miles than I thought....
12-23-2005, 07:33 PM
#28
Year: 1985
Rated Cap: 60
Here are some pics of the tank modifications: http://www.skoolie.net/gallery2/album52?page=1
12-29-2005, 05:52 PM
#29
Year: 1985
Rated Cap: 60
Woot! The tank is D-O-N-E!!
Here's the heat exchanger assembly that is mounted to it:
Here's the finished mounting:
Ain't it purty?!?!
Of course, once it's under the bus, no one will ever see it again....but we'll know it's pretty...
It took me 3 hours yesterday to drill 8 1/2" holes in the frame for the mounting bolts for the tank mounts. Jeez, Louise! That frame is 1/2" thick!
Tomorrow I have to measure for the fuel lines and radiator hose lines. I'm reckoning on just about 40' of each. It's 12 feet from the firewall to the middle of the tank, and I have a return and supply line for both the coolant and the fuel.
Lessee....40' x 2 x $1.++/foot....there goes ANOTHER hundred dollars... I'll have to drive another 240 miles on WVO to reach that elusive breakeven point....
12-30-2005, 02:03 PM
#30
Year: 1985
Rated Cap: 60
Okay. I'm going to mount the tank today. My day off, and I oversleep by 3 hours...sheesh! It looks like I'll need 21 feet of hose for each line, so I'm going to buy 25 feet (x 4 lines). I don't forsee any problem tying in to the radiator lines that go to the driver's heater. They have some standard fittings and gate valves that will be easy to deal with. The fuel line has me a little more concerned. I think I'm going to tie it in to the line that comes from the (diesel) fuel filters to the injection rail. My concern is that the pressure in this line will be too great for my WVO line and the electric valve that I got to control the tank selection. The valve is rated for 65 PSI, but I have no idea what kind of pressure is in the diesel line going to the injector rail.
Any suggestions?
Gotta go drop another chunk of change...
01-02-2006, 08:12 PM
#31
the fuel goes into the lifter pump (12volt or mechanical) then heads off to the fuel filter. From there it goes to the injector pump The fuel is not under much pressure until after it goes through the injector pump. Sometiems the lifter pump is connected physically to the injector pump.
There are two methods that i've seen commonly for tapping into the steel fuel lines....
the most proffessional looking method is to use a threaded "T" where the fuel line connects to the fuel filter, usualy 3/8" npt.
the other option is to just cut the steel fuel line and attach the "t" using rubber fuel line over top of the steel and held in place with hose clamps. I have a Mercedes Benz from 1977, and it came from the factory with this setup.
the steel fuel lines themselves use some sort of compression fitting, but i never had a convienent sorce for them.
01-02-2006, 09:19 PM
#32
Year: 1985
Rated Cap: 60
Thanks! That's a MAJOR help!
That's exactly what I had decided to do. I'm going to TEE into the fuel line where it comes out of the final oil filter (in the set of two). I'll use a close nipple and a TEE. The fuel line has the kind of fittings you mentioned. It is covered with some kind of braided fabric, and is flexible, but I'm not sure what is inside, so I don't want to go cutting and splicing it.
I soldered some on my heat exchanger this evening. After all my worries, I'm going with a copper heat exchanger. I just don't have the capabilitie$ or time right now to have a SS one made up. It's a 2' long piece of 1" copper pipe that will have a 1/2" pipe running through it. All the fittings are copper. It's soldering together very easily (which makes me worry -- anything easy is usually the prelude to a major disaster). It consists of a 1/2" to 1" reducing coupling on each end that the 1/2" pipe will fit through for the coolant to flow through on its way to the tank mounted heat exchanger; and three 1" copper TEEs, two at the ends and one in the middle. The two end TEE will be for the WVO to enter and exit through, and the middle TEE is for mounting a temperature gauge sending unit in. The process of making this is too messy for taking pictures (read, I was in a hurry), so I'll only have a photo of the finished unit. I'm going to mount it to the firewall somewhere under the hood.
I bought an electric temperature gage (Sunpro model) because I can get another sending unit for it, and put one in the heat exchanger under the hood, and one in the drain plug in the tank. Then I can use a switch (TRACTOR BEAM/PHOTON TORPEDO) to check the temperature in each location with one gauge. The mechanical temperature gauges have a 6' tubing linkage, and that limits the distance from the gauge to the heat source (plus, only one unit can be hooked to a gauge). The electric ones work "with any length wire", so that way I can monitor the tank, which is farther than 6' from the dashboard where the gauge will be mounted.
Thanks, again, Lapeer! That information is extremely helpful!
01-03-2006, 06:41 AM
#33
My international dt360 motor has fuel lines like the ones you mention. Inside the braided fabric are plastic fuel lines. Mine are rather stiff, but still somewhat flexible. I spliced into mine and was able to put tight fitting rubber fuel line over top of the plastic fuel line and hose clamp it in place.
just thought i'd share
I still think the preferred method is the one you are planning on utilizing the npt fittings on the fuel filter.
01-04-2006, 11:03 PM
#34
Year: 1985
Rated Cap: 60
Gods, will it never end?!?! I spent the past two days under the bus doing various things (when I wasn't running to Lowes to give them all my $$). The tank is hung. Talk about a tight squeeze! It just barely nudges the skirting out ever so slightly. I used to jacks to lift it and push it into place.
The fuel and coolant lines are run from the tank up to the engine compartment. I used pipe hanger clamps to hold them in place along their run, the galvanized kind that screws down on either side. I used #10 x 5/8" self-drilling screws, and MAN, was that a lifesaver. Well worth the expense. The fuel supply line and the coolant line to the tank are both insulated. The return lines (coolant from tank and fuel return) are not.
The big bear right now is mounting my final heat exchanger under the hood. It's going to take a bit of fabrication to get it mounted, that and relocating the horns. I want it mounted to the body instead of anything attached to the engine itself. I also still need to mount the fuel selector valve. Then i need to splice the lines.
Oh, yeah, I have to cut some kind of fuel filler access in the sheetmetal of the bus, as right now there is no access to the fill tube on the tank!
Oh, yeah, I also have to actually find some WVO somewhere...otherwise, this is an awfully expensive and complicated spare diesel tank...
(I do plan to put diesel in it to test the system out.)
Here's what it looks like with the tank installed
Bigger picture of it here.
01-05-2006, 04:41 AM
#35
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Hang in there with it, Eric! It will all be worth the time, $$$, and effort further down the road where you'll be rewarded with lower fuel costs, plus, look at what you've LEARNED!
Learning is living & vice versa. I think what you've done with your bus so far is great! I know I have learned from it. And while I don't have a diesel NOW, my next bus may, and it'll be easier for me because of all the bus growing pains I've watched you and others go through!
01-06-2006, 02:57 PM
#36
Year: 1985
Rated Cap: 60
Yippee! Incremental progress!!
I got all the plumbing (fuel lines, coolant lines) run finally! The lines run from the tank to the engine compartment, where they dead end for now. I was going to try to hook them up, but since I'm moving today, I decided not to cut any Important Parts on a day when I intend on driving the bus. You know how that kind of thing goes....
I got the heat exchanger installed, but not in the engine compartment. It's located roughly beneath the driver's seat. There will only be about 5 feet from that location to the injector pump, so the fuel shouldn't cool too much in that distance, especially since the line is insulated. The exchanger is mounted to the frame with three pieces of 1/8" steel for brackets, and connected to those by 1" pipe hanging clamps on 3/8" all-thread. It shouldn't vibrate much at all.
At least the major part of the work is done (I hope). Still have to mount the fuel selector valve, and plumb the final connections under the hood. Also have to wire up the fuel pump (wire is run) and the fuel selector and the sending unit for the WVO tank. I'm moving to the park this evening, and that kind of minor work I can do there without disturbing people.
Oh, gotta cut a fuel filler hole in the side of the bus!
More recent pics here.
01-09-2006, 12:57 PM
#37
looks like it's really comming together nicely!
01-09-2006, 01:53 PM
#38
Year: 1985
Rated Cap: 60
Thanks! I'm at a tiny bit of a slowing point, since school just started, but I hope to make "incremental progress"... I have yet to hook up the lines and mount the fuel selector and wire the gauges and wire the 120VAC heater element in the tank. But at least I got all the noisy stuff done before I moved on Friday (the parts that required loud swearing and throwing of power tools). I'm living at the state park where I work now. It's nice to hear owls at night...instead of crackheads!
01-10-2006, 01:31 PM
#39
I recommend you install insulation on the fuel return lines anyway, this will dump pre-warmed fuel back into the tank at somewhat higher temps.
And if you can, insulate the tank where possible.
The advantage to this is to use a little more of that "free" heat to prewarm the tank.
Y'see, the oil temp will rise 'x' amount of degrees during it's run to the injectors. If it's a 80 degree temp rise, then if the tank's ambient veg temp is 50 degrees you can expect a 130 degree fuel temp at the injectors. The hotter, the thinner.
BUT if it's only 25 out, the veg temp will only rise to 105 degrees, probably still too cold to use. Am I right here?
Anyway, something to consider....I'm curious as to WVO conversion, as I plan on doing something like it someday, and will lurk until I have drained everyone here of all knowledge.
01-11-2006, 07:32 AM
#40
Year: 1985
Rated Cap: 60
I have been thinking about going back and insulating the return lines. When I installed the lines, I insulated them with polyethelyene pipe insulation, the kind that is pre-slit almost all the way through. I slid the insulation over the lines without slitting it, so that I wouldn't have to go back and tape it up to seal it. I wish I had done that with the return lines. I can go back and insulate them, but I either have to unfasten them and slide the insulation over the lines (probable course of action) or slit the foam and seal it shut after I insulate the lines (I really don't like that idea).
I am planning on insulating the tank, although it will cover up that pretty red paint. There is a self-adhesive insulation material that is used in the HVAC industry that I would like to use, but I don't have a source for it yet. It is a foam-rubber material that has a metal foil on one side and adhesive on the rubber face. I think it has about an R2 factor in 1/4" thickness, which is better than nothing. I can find it as pipe insulation sold in 2" wide strips at the hardware store, but I know it comes in sheets, as well, and that's what I want.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Newbie here with a request
rcarr72 |
Skoolie Conversion Projects |
1 |
11-08-2013 12:55 PM |
Iowa Registration process
iowacamper |
Titles, Insurance, Registration and Money Matters |
1 |
07-02-2013 04:03 AM |
picture request
somewhereinusa |
Conversion General Discussions |
6 |
04-17-2013 01:42 PM |
Lost title process?
Griff |
Everything Else | General Skoolie Discussions |
2 |
06-17-2005 02:29 PM |
Page 6 added....
Vern1 |
5 |
04-22-2004 08:38 AM |
