05-30-2019, 01:37 PM
#941
Originally Posted by MIKE N STEPH
i think a call to the state level would make your comment about your title still being valid null and void once you receive your valid transferable registration from vt it is now a vt registered vehicle and would come up through a vin check that way thus making your ga title invalid
When I called Vt. to gather info I was able to get right through to someone. Now that I'm ready to see how much money to send I can't get through, phone line is busy until 4:30, they quit taking calls at 4:20.
05-30-2019, 01:50 PM
#942
Chassis: 3500
Engine: 6.6L
Originally Posted by o1marc
when i called vt. To gather info i was able to get right through to someone. Now that i'm ready to see how much money to send i can't get through, phone line is busy until 4:30, they quit taking calls at 4:20.
yeah the biggest complaint with the vt dmv is trying to get through on the phone
05-30-2019, 01:59 PM
#943
Did you type out my quote, it is completely different than the original?
05-30-2019, 02:04 PM
#944
Chassis: 3500
Engine: 6.6L
did you type out my quote, it is completely different than the original?
no i just used the quote button at the bottom
05-30-2019, 03:29 PM
#945
Now that IS funny!!!!
05-30-2019, 04:19 PM
#946
Originally Posted by deeplist
Hi everybody. I just recently purchased a 1998 International 3800 with a Thomas body from a school over in Ohio. I reside in Indiana. I will admit that I haven't read completely through this thread in its entirety simply because of the length, but I have skimmed over a good portion of it. I tried in the past to register a bus with Indiana (It was a 2002 International that I purchased at an auction) and it was an absolute disaster with the BMV. I finally just gave up and ended up selling it to a private school.
I'm going to attempt to do this Vermont transferable registration process on my 98. Before I mail this off, I want to run over the documents that I have and see if there's something that I'm missing OR if there's something in there that I DON'T need to send.
1) I have the Vermont application form with "TK" listed as the model, and "MH" as the body type. The "truck" section was left blank. The rest of the information was filled out as directed on the first page of the thread.
2) I had a local city cop come out and fill out a Vermont "Verification of VIN" form. He was apprehensive to do so, but reluctantly did. I don't know if that was needed or not, but I have it regardless.
3) I included a copy of the original Bill of Sale with notarized signatures of mine (buyer) and of the agent for the school (seller) with dates and purchase prices noted.
4) I included a copy of the Ohio Title that the seller signed off on and it was notarized as well.
5) I have a hand written letter, signed and dated by me, indicating the conversion from BS to MH.
6) Check to Vermont BMV for the $214 ($76 registration + $138 in tax ... which is 6% of $2300)
Is there anything that I'm missing or that should be added/removed from this packet before I seal it and send it off? Any suggestions?
For "Make" in section 5 you're going to want to put "AMTC" (I'm assuming your bus info in your profile is correct). For "Registration/Plate Type" in section 4 you want "Motor Home | 19". Make sure to fill out section 3B with seller's name and address and the sale date (you don't need VT Dealer number or the seller's signature).
I don't think you want to include the hand-written letter about the conversion, that's just inviting complications. I did not include any such letter (I have my VT tags now) - I think the person that ended up having to send this letter had filled out some info in the truck section, so as long as you omit that you should not need the letter.
I think you have everything else correct.
05-30-2019, 04:27 PM
#947
Once I'm done with my conversion I'm planning to register it in PA (to match the PA title), so I'll find out whether they just issue a PA registration and ignore the VT one or whether they issue me a new title and reg from the transferrable VT registration. Or whether they just clap me in irons for flouting their authora-tie in this manner.
05-30-2019, 04:55 PM
#948
Normally it quotes exactly, look at the omission of all caps in the quote
I think I just realized YOU have a cap lock on your computer, there's no upper case in any of your posts.
05-30-2019, 04:58 PM
#949
What do you do in the sellers section when you are the owner and not registering a new purchase?
05-30-2019, 06:58 PM
#950
Rated Cap: 71
Okay great! Under the "make" I had "International" so I'll adjust that and re-print the form with "AMTC" in there instead. And sections 3B and 4 I already had filled out correctly... so we're good there. Aaaaand, I'll pull out the letter of explanation and toss it.
I'll mail this out tomorrow and cross my fingers! Thank you!!!
05-30-2019, 07:36 PM
#951
Isn't Year/make/model- 1998 International 3800. Mine would be a 99 International Genesis.
05-30-2019, 08:00 PM
#952
Member
Registering rv w out Conversion
Okay thank you I will follow these notations.
05-31-2019, 08:43 AM
#953
It's honestly one of the most confusing things I've ever encountered. I knew my bus as an "International" but the title I originally received said "AM/TR" for the make, which is/was NY's abbreviation for American Transportation Corporation, which had already officially changed its name to International before my bus was built in 2003 but the title still said AM/TR for whatever reason (probably NY had not yet created an official designation for "International").
My PA title went with "AMERICAN TRAN" for the make. When I called the Vermont DMV and explained (attempted) what my make was, she told me to go with "AMTC" which is the VT designation for Internationals. So my actual VT registration says "AMTC" for the make. My insurance says "American Tra", continuing the chain of confusion.
So I'm pretty sure a '98 International would also be officially an American Transportation Corporation make, at least as far as VT is concerned. It probably actually doesn't really matter as I doubt the Vermont DMV actually checks up on it in any way.
05-31-2019, 01:12 PM
#954
Rated Cap: 71
I went ahead and put what you said on the application and reprinted it. Unfortunately, the VIN Inspection Form had "International 3800" as the make and model. I already went through the hassle of having the cop come out and fill out his area of the paper, and I wasn't about to reprint that one, and have him come out again, plus pay another fee. The way he acted filing it out the first time around lead me to believe that he probably wouldn't do it again.
05-31-2019, 01:26 PM
#955
I'm pretty sure even an average bureaucrat will be able to make the connection.
But including an explanatory Post-It note wouldn't hurt.
05-31-2019, 01:38 PM
#956
Chassis: IH 3800, 8 window
Protect and serve... [emoji51]
05-31-2019, 01:51 PM
#957
You have to pay for a VIN verification? It's part of the cops job, he can't decide not to do it. I had mine done last week, on Fri, holiday weekend. Call late afternoon to set up a time later in the week, he showed up 30 minutes later.
05-31-2019, 01:55 PM
#958
Hmm, that's unfortunate. The lady at the Vermont DMV said that the make on the form has to be one of the codes from their list, and she went with AMTC because that matched my title (which says "AMERICAN TRAN"). What is the make on your title?
05-31-2019, 01:58 PM
#959
Maybe cops where you are have a different idea of their duties. The Philly police department I called about a VIN verification basically said "**** no, we don't do anything like that".
05-31-2019, 02:05 PM
#960
Rated Cap: 71
The Ohio title said "INTL" as the make. Hopefully, it's okay. And if not, it's too late to change it now, because the mail has already ran for today and the packet is on the way to Vermont.
The city cops here charge a $5 fee to do a VIN check and run the numbers through the NCIC database. The county sheriff doesn't charge anything, but they won't come out and do the check if you live within the city limits.
