Old 08-30-2018, 12:03 PM   #1
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Importing to California questions
Hello all - got a compound question here:
Situation is that I am looking to purchase a bus that is >26,000 and I currently have a Class C license.
There are a couple of things here that need figuring out:
I am in
  • California - which has stricter emissions laws - bring in an out of state diesel engine is an unknown process
  • How to get a "bus" with seats home on a class C license before it's reclassified as a MH
  • what are the registration requirements in CA for a BU to MH reclassification - ambiguous
at the DMV and definitions in state vehicle code.
So here's what I came up with:
Registe
  • r bus in VT following the process in another thread here to get the bus converted to a MH on the registration and title (this takes a minimum of two weeks)
  • Remove seats from bus prior to trip home
  • Once the bus is back in CA (and after 90 days to avoid double tax) register it here - since it's already registered in a MH in VT, then it -should- be exempt from FED and CARB emissions requirements as it's already a MH and they are exempt at th
e federal level.
So... looking for anyone who has done this (California specific) and can tell me if this plan will or will not work.
Thanks...
Pizote is offline   Reply With Quote
Old 08-30-2018, 12:37 PM   #2
Definitive info regarding CA has been difficult for me to pin down. I did find the following on the DMV website:
Does my vehicle qualify for a smog exemption?
Smog inspections are required unless your vehicle is:
Gasoline powered 1975 year model or older
Diesel powered 1997 year model and older or with a Gross Vehicle Weight rating (GVWR) of more than 14,000 lbs
Electric
Natural gas powered with a GVWR rating of more than 14,000 lbs.
Motorcycle
I did also find (and lose) a mention of exemption from DPF retrofit on RV's. If it is 1998 or newer, it would appear that you will have to go through emissions testing.
We have plenty of CA skoolies. Speak up. What has your experience been?
Old 08-30-2018, 01:58 PM   #3
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Thanks Steve - this is the exact same info that I have found out.
Old 08-30-2018, 04:37 PM   #4
A class C license in Ca. is only good at or below 26000 pounds.
Here is the Ca DMV link:
https://www.dmv.ca.gov/portal/dmv/de..._htm/lic_chart.
Old 08-30-2018, 05:00 PM   #5
Here again I read this as no special license is needed for a "house car", regardless of weight. (why does spell check want to change house car to house boat?)
When they bring up weight I will ask them their definition of "any".
Old 08-30-2018, 05:18 PM   #6
It's pretty clear that California requires an upgraded license (class A or B non-commercial) if your RV is over 40' or 26000 lbs.
Good news is that they don't require a CDL.
Old 08-30-2018, 05:20 PM   #7
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Here's the full text of the DMV has on Class C licenses:
With a Basic Class C license:
A 2-axle vehicle with a GVWR of 26,000 lbs. or less.
A 3-axle vehicle weighing 6,000 lbs. gross or less.
A motorized scooter.
Any housecar 40'or less.
A farmer or employee of a farmer may also drive:
Any combination of vehicles with a Gross Combination Weight Rating (GCWR) of 26,000 lbs. or less if used exclusively in agricultural operations and it is not for hire.
Note the "Any housecar 40'or less.
If it's registered as a BU, then a Class C can't legally drive >26,000lbs. If it's registered as an MH (Motorhome/housecar) then you can drive any weight vehicle as long as it's 40' or less.
Old 08-30-2018, 05:23 PM   #8
Well most school buses are not over 40" and the law there says I can drive "ANY housecar".
Here in Ga, it says "All RV's". I questioned the people at DMV if this meant regardless of weight or brakes, she said "what does ALL mean to you?"
I'm waiting for Ca.DMV to call me back to get their definition of "house car"
I realize this doesn't help you get it in the state, but it's nice to know when it's converted, even in Cal. you don't need a CDL.
Old 08-30-2018, 05:27 PM   #9
Pizote,
Can you share with us where you found that? When I searched CA DMV i came up with the same info that Ol Trunt did. I wonder if there may be contradicting info on the DMV site?
Old 08-30-2018, 05:33 PM   #10
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Pizote,
Look at the third post of this thread - it's a link to the CA DMV License requirements.
Here it is again for good measure:
CA DMV DL Restrictions: https://www.dmv.ca.gov/portal/dmv/de...dl648/dl648pt2
Old 08-30-2018, 05:37 PM   #11
Pizote,
Old 08-30-2018, 05:40 PM   #12
That is a link to the DMV site.
Can you share with us where you found the info you quoted?
Thanks
Old 08-30-2018, 05:45 PM   #13
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Thanks
Umm... that is where I got it from. Click on the link, it displays a table, look for Class C in the left column and in there you will see the text I cut and pasted.
Old 08-30-2018, 05:52 PM   #14
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Thanks
You can also find the exact same text on the CA Legislature site (12804.9 (a)(3))
CA Legislature on DL Class Types
Old 08-30-2018, 05:54 PM   #15
Thanks
My link is to the chart.
Old 08-30-2018, 05:57 PM   #16
Thank you Marc. That link worked.
When I Googled I found a near identical chart but without the "housecar" exemption. Ol Trunt's link is similar. All from the DMV website.
Looking like CA DMV is confused.
Old 08-30-2018, 06:17 PM   #17
The State of California is confused.
Old 09-14-2018, 10:25 AM   #18
Engine: 7.3 DT444E
Rated Cap: 71
I also have a "heavy" bus that I am importing to California. I followed instructions listed on another thread to register the bus in Vermont. When filling out the application, I listed my "loaded weight" at 26,000lbs....I don't believe I was the only one to do so. My bus is not longer than 40ft, and I don't plan on ever loading enough weight to put me over 26,000. I would say that it is highly unlikely that I will ever run into problems....
I was once pulled over while driving a 26ft box truck and the officer was new to the force. When I provided her with my class C license, she intially thought I needed a CDL. I told her I didn't believe this to be the case and she hopped on the radio to ask. In less than a few minutes I was back on the road with no ticket to speak of. She didn't have the means to weigh my truck there on the spot, nor the inclination. I would think that if I had overloaded my vehicle and passed through a weigh station things would go very differently however. Luckily for us, busses are not required to weigh in. And if you have a registration listing your bus as a motor home, I'm sure you will be fine in the Golden State.
Calibuslife is offline   Reply With Quote
