Old 01-16-2018, 11:23 AM   #1
Insuring a pre conversion school bus in California???
I知 having trouble trying to find insurance. It seems as though no one wants to insure a pre conversion school bus due to school busses typically having narrowed axles and at higher risk of roll over after conversion. Who do people on here in California use to insure their busses to get them purchased and moved to do the conversion? I知 looking at buying a 2003 TC2000. Any help would be greatly appreciated.
Thank you,
Mike
Socaliwelder is offline   Reply With Quote
Old 01-16-2018, 12:03 PM   #2
Robin97396's Avatar
Go to an independent insurance agent. Tell them you want a "commercial policy for private use" and let them do the shopping for you. You'll likely end up on Progressive.
Robin
Nobody's Business
Old 01-16-2018, 12:12 PM   #3
brokedown's Avatar
Insurance also varies wildly by state so it's hard to give someone advice if they're not local to you. +1 on Robin's suggestion.
Old 01-16-2018, 03:25 PM   #4
Are our buses any heavier after conversion than they would have been fully laden with passengers?
Old 01-16-2018, 03:30 PM   #5
Chassis: Saf-T-Liner MVP ER
Normally no, they are considerably lighter.
71 pax @ 80 lb
24 seats @ 80lb
That's over 3 tons in weight. Few people will add anything close to that in an RV build-out.
This is one reason why it might pay to reduce the spring rates.
Steve Bracken
Build Thread
Old 01-16-2018, 03:31 PM   #6
The bus manufactures use 80lbs per student to figure capacity. A 72 passenger bus full is expected to carry 5760 lbs of kids. Add to that 12 seats at about 100lbs each.
That will give you almost 7000 lbs of "payload" capacity. I think that you will have to really work at it to exceed 7000 lbs in your conversion.
Old 01-16-2018, 03:50 PM   #7
71 pax @ 80 lb
24 seats @ 80lb
80lbs sounds like they are using an elementary school bus and a not a high school bus. I seriously doubt the average weight of a high school student is 80lbs.
Just checked, average weight of a high schooler is 113.5 if the same amount of students is considered. Full load in a 72pass. is 8172 just in pass. weight.
Old 01-16-2018, 03:53 PM   #8
80lb is the official weight used to calculate three kids to a bench seat. That's how you get to 71/72 passengers.
If you use a higher weight you have to reduce the number of pax to 2 passengers per seat.
That same bus would carry 48 high school students
Steve Bracken
Build Thread
Old 01-16-2018, 04:05 PM   #9
Makes sense, so 5448lbs total pass. weight
Old 01-16-2018, 06:35 PM   #10
In Texas where we have way too many fat kids...I hope they are using at least 220 lbs. per butt.
Old 01-16-2018, 06:41 PM   #11
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
You sure that isn't 220 lbs per cheek?
Old 05-23-2019, 09:58 PM   #12
Thank you,
Mike
Hey Mike
Did you ever figure out insurance? Down in LA here and about to try and deal with it myself. Any advice is appreciated.
thanks
goose
eevlgoose is offline   Reply With Quote
Old 05-23-2019, 10:15 PM   #13
Call AIS. I got mine through them in about an hour
