Old 05-24-2010, 08:45 PM   #1
Stuff's Avatar
Re: :) Is a GMC Vandura Shortbus Insurable as a Van?
try for van or something. getting 'bus' off of it is the biggest thing when going to rv
Old 05-24-2010, 10:09 PM   #2
lornaschinske's Avatar
Rated Cap: 89
You should be able to tile as a van or a "Class C" RV . My Class C is on a GMC Vandura 35 chassis. I also think that my 1977 Chassis is more than a 3/4 ton. I have the van part of the owners manual around here somewhere. I think my RV is 2 ton.
Fulltime since 2006
Old 05-24-2010, 10:11 PM   #3
Stuff's Avatar
looks like a chev 3500
Old 05-26-2010, 09:54 AM   #4
Stuff's Avatar
ohh.. maybe register it as a cube van. remove the seats though. and claim seating for 1-3 people then.
Old 05-29-2010, 08:18 AM   #5
Year: 95
Chassis: GMC 3500
Engine: 6.5 diesel
I have almost the same thing, 95 GMC Vandura 3500 with the 6.5L. I think Chev used G30 and GMC used 3500 for there 1 ton chassis designations.
In Wisconsin being 10,000lbs and under, if you leave over 50% of the seating in it is considered a passenger car similar to a suburban or passenger van. Your state may be similar.
If I had removed all the seats it would have been considered a 1 ton truck which in WI doubles the yearly tabs. Now that I have mine titled I am switching out the remaining seats and replacing with smaller coach seats on tracks. Then I can slide them out of the way for hauling. As long as I have 8 seat belts somewhere I should be fine.
When it came to both insurance and the DMV, I explained that I currently drive a suburban and would be using it just as I would that. For personal use only. Trips to Home Depot for supplies and transporting family and such. No commercial use needed to pointed out a few times.
I only put Liability insurance on it so that probably made it easier. I sold an old beater car to buy this so I didn't notice a change in cost.
Good luck with your purchase.
snonbos is offline   Reply With Quote
Old 06-03-2010, 11:28 PM   #6
Year: 95
Chassis: GMC 3500
Engine: 6.5 diesel
Originally Posted by Smitty
I thought 1500, 2500, 3500 was truck chassis.......
G10, G20, G30 was van chassis..........
Smitty
That's what I was thinking when I first picked the bus up. But my GMC has "Vandura 3500" badge on the fenders.
As I see vans around it seems the Chevrolet branded vans of this era have G series numbering and GMC vans have the 3500 etc numbering(?). Not sure why Chev/Gmc use different number scheme? Probably so people can tell the difference between them?
I'm not sure if I did it right, but when I punched in the VIN# on the Geico website it came up as a g30 cube van.
Yep, the VIN is for the van chassis. I told my agent about it being a short bus but they went off the VIN # and insured it as a van. They were more concerned about it not being used commercially or to haul people.
but taking the seats out today made me want to pass out about . . . now zzzzzzZZZZZzzz
Luckily we only had 8 seats to take out
My seat removal progression
First seat: carefully remove bolts with socket and wrench. set seat in yard hoping to find a use for it.
by the time I got to the Last seat: Grinder w/cutoff wheel and sawzall, throw chunks and pieces of what used to be a seat out the back door.
Currently working on updated pic's.
Old 09-02-2010, 12:11 PM   #7
Year: 97
Engine: GMC 6.1 Diesel
Rated Cap: 22
I've got a very similar bus that I've reached the point where I'm getting ready to start converting the interior. Already have all the seats removed and I painted it also. I'm at the point where I need to register and insure it now. I'll be watching this post to pick up pointers on the insurance and modifications to the interior. Mine's a 97 GMC 6.1 diesel in terrific shape that I bought off Ebay for $3,000. Absolutely nothing wrong with it.
Littlebadwolf is offline   Reply With Quote
Old 09-28-2010, 08:48 AM   #8
Chassis: flatnose
Engine: 5.9 cummins turbo
Rated Cap: 48
i live in florida you can title that as a rv as long as you have 1 110 outlet they don't check you just sign a paper. the title transfer has jumped up to 75.00 just for the title it was 29.50 just a couple years ago. they stick it to you.
bluebird flatnose is offline   Reply With Quote
Old 06-13-2022, 04:30 PM   #9
I just did mine today in Florida. Had to get it weighed and1 of 3 things had to be done. Water plumbing, propane line or electric. Cost me over $100
Lisab is offline   Reply With Quote
1993 GMC Vandura with Mid Bus/Worthington body electrics Vintshave Skoolie Conversion Projects 2 11-04-2014 03:50 AM
1987 Bluebird Vandura Mini - intro chev49 Skoolie Conversion Projects 2 08-09-2012 04:22 AM
Found 1991 GMC vandura 3500 short bus baltimore md Stuff Classifieds | Buy, Sell, Swap 0 08-06-2011 09:55 PM
FS 1992 GMC Vandura (Short Bus) dark_bassline Classifieds | Buy, Sell, Swap 2 06-04-2008 05:00 PM
1992 gmc vandura speed sensor finfan3dp Everything Else | General Skoolie Discussions 0 04-16-2005 05:39 PM
