Old 02-26-2018, 01:22 PM   #1
2kool4skool's Avatar
Need to take CDL exam?
Go here first; America's Independent Truckers' Association
Getting an AITA card gives you a nice discounts on parts at NAPA too.
Don, Mary and Spooky the cat.
Old 02-26-2018, 01:32 PM   #2
Thanks for sharing that.
While most of us don't need CDL I think that learning about our buses and taking the practice exams would be beneficial.
Old 02-26-2018, 03:42 PM   #3
I didn't think my state required CDL to drive a large RV or bus conversion. It used to not be a requirement, now it is. Well, sort of. It's new classifications a person can get for different vehicles and operations. One is an RV over a certain size, air brake, and towing because of length and weight. I'm sure there are a lot of people out there that have not gotten the proper endorsement(?) on their license. It's a computer test and a driving test in your equipment registered to you.
ben2go is offline   Reply With Quote
Old 02-26-2018, 04:21 PM   #4
Chassis: Saf-T-Liner MVP ER
Be clear ... What you are describing is a Non-Commercial Class B (letter may vary) on your regular state driver's license.
Steve Bracken
Build Thread
Old 02-26-2018, 04:29 PM   #5
Yes correct. I forgot to add that in there. There are a few other classes or endorsements that can be gotten for bus and pulling a trailer.
Old 02-26-2018, 04:59 PM   #6
Non-Commercial Class B - Vehicles 26001 lbs or more
Non-Commercial Class A - Vehicle pulling a trailer in excess of 10000 lb (Semi)
In a few states the letters vary ... May be E or F
In some states your regular license is all you need (I'm looking at you, Oklahoma).
The Class B is all most would need as a school bus isn't likely to pull a trailer over 10000 lbs, but if you do, be warned.
Steve Bracken
Build Thread
Old 02-27-2018, 07:27 AM   #7
Not sure of the exact lettering here but that's the jest of it. I wouldn't pull 10,000lbs but I would pull my Ranger. It will weight about 4400lbs when it's done.
Old 03-02-2018, 11:49 AM   #8
jonb8's Avatar
Engine: 466
I've done some research in WV and it looks like I am going to have to get a CDL. Anything over 26,000 and air brakes endorsement.... UHGGGGG I'm glad I've givin myself 3 years for this project, seems like I'm going to need it.
jonb8 is offline   Reply With Quote
Old 03-02-2018, 12:19 PM   #9
Unless you plan on using the "C" in CDL (i.e., operating your vehicle for "Commercial" purposes)...you should not need a CDL license. That said, many states do have limits on what you can operate with just a standard issue drivers license. Anything over a certain weight, length, etc. and sometimes for air brakes, but those requirements are met by adding an endorsement to your regular license. Same as a motorcycle endorsement. The CDL is a Federal/interstate mandate as I understand it, and states cannot impose those requirements.
If anyone knows otherwise...please...chime in. This seems to come up at least once a week.
Old 03-02-2018, 12:30 PM   #10
Can you point me to where you found this info?
I did a search and found conflicting information.
The WV site makes no mention of RV license requirements that I could find. It does simply state that vehicles over 26k require a CDL.
There are a couple of websites that claim no CDL for RV's in WV. No mention of size or brakes.
Old 03-02-2018, 04:31 PM   #11
I would certainly call or visit your local motor vehicle division and get the specs on what you need to drive what you plan to drive.
Old 03-02-2018, 07:40 PM   #12
Asetechrail's Avatar
Coachwork: Amtran Genesis
RV Driver's License Requirements
Asetechrail is offline   Reply With Quote
Old 03-03-2018, 08:36 AM   #13
Originally Posted by Asetechrail View Post
That is only kind of accurate. It's accurate to 2007. My state has added other things to the list of endorsements.
Old 03-03-2018, 10:59 AM   #14
Hey good to know! I won’t ever post that again.
Old 03-03-2018, 03:56 PM   #15
It's still good info to get people pointed in the right direction.
