NY Preparing to Purchase HELP
I have been searching for the perfect bus to purchase, Im located near nyc and am willing to go a few hundred miles. That said, I at one point had my mind made up on a Flat Nose International with a DT466. Plan is to make a camper/van rv. Less than 15 seats.
I love the flat nose look however will consider other options, I want atleast 6ft interior and the DT466 seems to be the best engine bc Ill be making a trip to Michigan from NY this summer.
Ive found a few 2000/2001 internationals close by with DT466 they're in great shape and Ive even found a broker to inure with progressive commercial (private use)
What I can't figure out is if I will actually need a CDL to drive the International Flat nose (no seats), its GRVW is 30,000 lbs. Ive read up on others successfully registering for under 26,000 lbs and not having issues but will I have problems if I get pulled over by DOT?
Ideally I would swap for a mid sized bus, 6ft interior height and under 26,000 just to be safe and be sure i won't have issues driving across the country. I understand things are different in every state though I just can't get a straight answer. I am considering getting my CDL but Ideally I would be able to ask friends to share some driving on long trips. And advice is appreciated. Thanks!
