Old 03-07-2018, 08:13 AM   #41
Chassis: E-450
Engine: 7.3 Turbo
Originally Posted by 25074 View Post
You need a CDL in Pennsylvania if you operate a vehicle over 26,000 pounds or a bus with more than 15 passengers.
My skoolie is rated at 14,000 pounds and now has only 4 seats.
For future reference, this is incorrect.
You do not automatically need a CDL just because your rig is over 26,000 pounds. From the PA PUB 223:
Exemptions: You do not need a CdL to drive military equipment while in military uniform; certain fire and
emergency equipment owned by a fire company; or recreational vehicles; implements of husbandry; or
certain motorized construction equipment.
Also, the passenger # drops to just 11 including the driver if the vehicle in question is a school bus (which I assume they would enforce if you didn't do any conversion work and left the bus as is).
It's been a while since I went and read how the actual laws read, but that is the interpretation of the law that is currently being taught to people by PENNDOT, which means that is probably how it will be enforced.
Our build thread
PigPen is offline   Reply With Quote
Old 03-07-2018, 08:43 AM   #42
I did not say my post was all inclusive. I simply explained my situation.
Here is the CDL fact sheet from Penndot
http://www.dot.state.pa.us/Public/DV...ets/fs-cdl.pdf
25074 is offline   Reply With Quote
Old 03-07-2018, 09:02 AM   #43
Chassis: AmTran
Engine: International DT466E 7.6L inline 6
You don't need a CDL if not using it for business. If your RV is over 26K you do need a class B or class A NON commercial added to your license.
Brasquatch is offline   Reply With Quote
Old 03-07-2018, 10:58 AM   #44
Chassis: Saf-T-Liner MVP ER
PA is also the only state that requires the Non-Commercial Class B for ANY vehicle with air-brakes, regardless of weight.
Steve Bracken
Build Thread
Old 03-30-2018, 10:02 PM   #45
Originally Posted by PigPen View Post
I'm planning on doing a full write up of everything I've learned, but I'll share the gist of it all now. For the record, I ended up going with a shortie that doesn't require any type of special license at all. We'll be starting our build thread shortly!
As far as the whole CDL thing goes, its REALLY complicated, to the point that there isn't a straight answer. CDL rules and licensing are actually based on federal standards that are enforced by each state. If you look at the actual wording of the legislation, FMCSA Standard 383, you'll see that the definition of a commercial vehicle includes three qualifications and if any are met, the vehicle counts as needing a license. Read carefully though, because the definition also states that the vehicle must be "used in commerce to transport passengers or property".
By the letter of the law, this means that as Roadrunner was pointing out, a vehicle with over a 26000 GVWR doesn't necessarily need a CDL. In PA, it technically needs a class b non-commercial license, but VERY few people actually get them. To be fully legal, you would need one though.
Heres where things get really complicated. From my understanding, a vehicles registration is basically your statement of intended use. Your options for how you can register a vehicle are connected to how it is titled. If your bus is titled as a bus when you get it, then your option for registering it seems to be as a bus and only as a bus. I'm not sure if you could get away with it being a truck or not. If you are stuck registering it as a bus, then it seems you're stating that you plan on using it as a bus (even though they forced you to choose that option). If you're registered as a bus over 26000 lbs, then you may be in a danger zone as far as what license they expect you to have if you were to be pulled over.
In order to retitle a bus as an RV (and by extension be able to register it as one as well), PA has a set of requirements you must meet. First you have to have at least 4 of the following:
• Cooking appliance
• Refrigerator
• Self-contained toilet
• Heating/Air conditioning
• Portable water supply
• Faucet and sink
• Separate 110/125 or LP gas supply
Once you have that, you have to have a special inspector come and take photographs with initials to verify everything. At that point, you would also need an enhanced vehicle inspection done at a special inspection station.
This is only to complete the RV retitling in PA. If you buy a bus already retitled, then it appears as though you are lucky and get to skip all these steps. Many states have very lax laws and if you declare an intention to use it as an RV, then that is good enough. (Side note: if you find a bus in a state that has easy title change rules, you may want to pay the owner to retitle it before you buy it. Just a thought and please verify that this will work ahead of time. Don't just rely on some random guy on the internet).
If you are buying a bus titled as a bus, then what you need to figure out is how to register it in a way that avoids special licenses. What ends up working for you will depend on who you talk to and what they are willing to do. According to my local notary/tag service, I can declare any GVWR between the one listed in the vehicle and the curb weight. The declared GVWR would become the maximum I'm allowed to use on public roadways and if caught exceeding that weight, hefty fines could ensue. This could be an interesting way to get a vehicle below the 26000 threshold until you complete the conversion and retitle as an RV.
Sorry if thats confusing. Like I said, I'll go back through and try to write a more thorough and thought out account of what I have learned. I spent several weeks discussing the matter with literally every person I could contact within PennDOT. This was essentially everyone, as I got a hold of their internal directory and just called every president, vp, and other bigwig on the list in the various departments. Most people directed me to one of a handful of people who I narrowed my focus to. They did not even know the answers and these are the people that are supposed to be making/enforcing/educating about these laws! What I laid out above is the basic account of what they shared, but when I tried to get more details or specifics it always came back to "I don't know, I'll check and call back tomorrow." Eventually they gave up and stopped calling back
Let me know if you want me to clarify anything!
I had the exact same experience with PennDOT. This Commonwealth is abysmal at serving its people in a commonsense customer focused manner. Looking forward to putting PA in my rear view asap.
Sent from my SM-G900V using Tapatalk
lmetts is offline   Reply With Quote
Old 05-26-2020, 06:27 AM   #46
You can register and title a bus in PA as a station wagon! I just did it in march
i have a 25 foot long 93 international 3700. youre telling me i can register it as a station wagon? please let me know if this is a real thing? lol
Cloud3GPS is offline   Reply With Quote
Old 05-26-2020, 11:30 AM   #47
Chassis: AmTran
40' AmTran and yup, 3 years now, no issues
Old 05-26-2020, 11:56 AM   #48
In PA you can change the body type of your bus to whatever you want (including motorhome) by mailing in form MV-41: http://www.dot.state.pa.us/Public/DV...orms/MV-41.pdf. There appears to be no checking on the validity of any such change. However, this form (and documentation elsewhere) states that:
If the vehicle has been modified, such as the addition or removal of axles, or you are requesting a change to the manufacturer weight specifications, Form MV-426B must be completed.
Form MV-426B is not just a form, it's a whole process whereby the vehicle and its modifications are inspected by a state inspector and an authorized mechanic (i.e. not you) signs off on them. My local tag & title person has taken three people through the process of getting their skoolies titled and registered as motorhomes in PA, and she insists that MV-426B is required for skoolies as (pretty obviously) modified vehicles.
I told her that people have changed it just by mailing in MV-41 and not MV-426B with it, and she is of the opinion that if a person who did this was ever pulled over by law enforcement, the lack of the modification form on record would lead to a retroactive revoking of the vehicle's title.
If you intend to do this, I would recommend calling PennDOT first and making sure it's legal. Although keep in mind that you will probably get different answers based on who you end up talking to. I called PennDOT about this a year ago and was told it is completely impossible to ever retitle a school bus in PA as anything other than "BUS" - something that is definitely not true, and she even went and got her supervisor who confirmed the untrue thing.
Old 07-01-2021, 07:14 PM   #49
in PA you have to change the registration over To change a title classification from Bus to any other body type in Pa you need an MV-41 form and $53, registration is $37 for a wagon $120 for a motorhome plus the agency fees. You can't just take a bus title and register it as a wagon or motorhome without changing the body type on the title first.
• Cooking appliance
• Refrigerator
• Faucet and sink
Nivasi on Wheels is offline   Reply With Quote
air brakes, cdl, pennsylvania, title
