Old 05-28-2018, 01:57 AM   #1
Sc or nc
Just moved I can use my NC address or my moms Sc address which would be easier to register will I have to change my title? Anything helps thanks
Lherrlinger is offline   Reply With Quote
Old 05-28-2018, 08:54 AM   #2
thrifty1's Avatar
Engine: DTA360
I just went to the scdmv with a title transfer request. Confused the hell out of three people but they accepted it with no pictures or anything. I requested that they mail the title instead of print it out right there. Big mistake. Itís been 8 weeks and I JUST NOW have been informed theyíve finally released it to be mailed to me as an rv instead of bus. So all in all it was very easy with no proof of conversion but took some time for the title to be changed over. YMMV
thrifty1 is offline   Reply With Quote
Old 05-28-2018, 10:09 AM   #3
Is it better to have changed into an rv title?
Old 05-28-2018, 10:13 AM   #4
thrifty1's Avatar
Engine: DTA360
Unless you have a cdl, definitely. You canít legally drive a school bus unless itís changed over. Plus insurability and taxation advantages.
Old 05-28-2018, 11:45 AM   #5
You can't legally drive a school bus "for profit or commercial use" without a CDL. You don't need to change anything over to drive it.
Old 05-28-2018, 11:48 AM   #6
The reason you want the title change to RV is because most insurance companies will not insure it as a bus, but will as an RV after at least 4 of the 6 criteria are met.Standard procedure is to obtain a "commercial for private use" policy while converting and then once finished, convert the title and insure as RV or MH.
Old 05-28-2018, 11:50 AM   #7
thrifty1's Avatar
Engine: DTA360
Why then, do you need a cdl to drive a church bus? Is that technically commercial? Iíve always assumed that a cdl was needed on that basis but could be wrong, itís happened before. A lot.
Old 05-28-2018, 11:57 AM   #8
Schools and Churches are considered commercial if it can carry 16 passengers.
Old 05-28-2018, 12:00 PM   #9
Why then, do you need a cdl to drive a church bus? Is that technically commercial? I’ve always assumed that a cdl was needed on that basis but could be wrong, it’s happened before. A lot.
It varies by state. Here in WA, if it will seat 16 or more people, you must have a CDL regardless of what you are using it for.
That is the law here.
Old 05-28-2018, 01:05 PM   #10
I live in NC, but have thought of using my SC address to register my city transit bus because NC still has "safety and emissions inspections. SC doesn't have "smog & emissions" inspections.
NC does meet the Federal clean air standards and was considering discontinuing these taxes, but the "State Inspection" stations are private businesses and hired lobbyist to continue the theft from vehicle owners.
vtxvette is offline   Reply With Quote
inspection, insurance coverage, registering, registrastion, titled as motorhome
