Old 12-14-2006, 12:29 AM   #11
the_experience03's Avatar
First things first....yes yes yes you want it registered either as an RV or a private bus. Some guys are getting better insurance rates on a private bus, but I'm not sure if you would given your age. There are also other benefits to being registered as an RV, but we don't need to go into that until you figure out if you have a choice in the first place. Again, what my agent told me is that the rates for RV's are NOT based on the age of the operator.
The 392 is a GREAT engine. Just make sure you find out the gear ratio of the rear and and if it has a governor. I can't imagine you want a bus that will only do 45. Part of having a skoolie is the journey, but 45 mph on the interstate might make things a bit too scenic.
You were correct in assuming that hydraulic brakes are like on a car. These use a pressurized fluid to move the shoes into contact with the drums. The difference, however, might come in the power assist system. While some buses with hydraulic brakes have a booster that uses engine vacuum to assist much like a car, it seems that far more have a hydraboost system instead. In this system, pressure from the power steering pump (which is essentially just a hydraulic pump ) is routed to a booster which then provides the vacuum assist. 1 ton pickups have had this system for YEARS and it tends to be very reliable.
Air brakes are kind of a different animal. I will go ahead and put my neck on the line in saying they stop better. This is the same system 18 wheelers and trains use, afterall. With air brakes, an air compressor on the engine will pump a set of air tanks under the chassis up to about 120 psi. When you step on the brake pedal (called a treadle in air brake applications), an amount of air is routed to the brakes. It is proportionate to how hard you push the pedal. Push harder and you put more pressure to the brakes. At the wheels themselves there will be chambers. Inside these are pistons which when pushed will move the shoes into contact with the drums. Additionally, your parking brakes will be air operated. The shoes in this system are held against the drums by heavy springs. When you push the release lever, air is applied against these springs causing them to retract. That means that you must have air pressure to start moving and if you lose air pressure on the road, the brakes will automatically come on.
I don't want to complicate things and admittedly I am not the best at describing these things with words so I'll let someone else try.
http://www.newbiedriver.com/ABCsUpda...rBrakes101.htm
Do make sure you read the air brake section of the CDL regulations. There are some important numbers to know and braking techniques to understand. I certainly hope I'm not scaring you away from them! They are a fantastic braking system. You just need to fully understand them. It does give you an air supply for running air tools, an air ride seat, BIG air horns....whatever you want!
If you choose to go with the Chevy buses, rest assured that the 366 is also a popular gasser motor and another well built piece. I *think* Chevy was actually the last company to offer a gas engine in a bus and it was the 366 with throttle body fuel injection.
As for convincing your parents....it might be hard at first, but after you buy it, make sure you make progress on it, but take your time. Make it look nice. Do a good job on the electrical and plumbing systems. Take shortcuts within what's safe to fit your budget, but don't let them know I'm sure they will come around. Just make sure you keep up on it. There are all too many half finished skoolie projects on eBay because people lose interest.
If your parents are anything like mine, and I bet they are, they will come around as they see it come together. My parents scoffed at the idea, but once they saw exactly what it was, they started to like it a little. Maybe you just need to take them camping once. They'll never go back.
Best of luck and keep us posted.
Old 12-14-2006, 12:08 PM   #12
Insurance
I just contacted an agent in State Farm Insurance and they said "If we COULD insure a converted bus with a 16-year old it would be for liability only."
I wonder what exactly that means. She said to call so thats what Im going to do.
Is liability insurance all the insurance that I need? By the way I am not planning to convert this bus to a RV. I simply just wanted to remove all the seats and install a stereo, Fog Machine, Lasers, and a strobe light for a party bus. Maybe leave a couple rows of seats in the front so i can haul around 15 people so its legal. Anyways get back to about if liability insurance is enough, given my details. Thanks
Daniel
OregonFan2008 is offline   Reply With Quote
Old 12-14-2006, 07:07 PM   #13
Yes, liability is the most insurance I've ever seen a state require. What it means is that if you hit someone else, their lose is covered (to a point...there are different levels of coverage) but yours is not. Of course if it is their fault, your insurance woon't matter. Accidents happen, but if you respect your bus for what it is, I don't think you should be causing many accidents. Just take care in those parking lots. Liability will likely include no-fault insurance as well for medical expenses.
Next time you talk to an insurance agent, say it is an RV, not a bus. Afterall, if the plates say it is an RV and the title says it is an RV, that's what it is, right? I probably wouldn't even throw them for a loop if you said the body manufacturer was Bluebird being that they have been doing the Wanderlodge thing for years. You aren't lying when you say it is a converted bus....you're just not volunteering information they didn't ask for. There's something so American about that idea....
Old 12-14-2006, 09:57 PM   #14
As far as what type of brakes you want. I will never own another bus with hydraulic brakes again. They have been a pain to deal with. The master cylinder in bad shape so I had to rebuild it, then a bunch of the steel brake lines were rusty and they had to be replaced. This all cost a lot of money.
At least with air brakes a you don't need to deal with brake fluid and a master cylinder. I don't like having to change the brake fluid, it is just one more maintaince hassle.
As far as insurance a lot of the cost has to do where you live. When we lived in Newberg it was high but not nearly as high as in Denver. Here in Idaho it is about 1/3 of what it was in Denver.
IMHO there is no reason to have anything more than liability. If you even have a small accident with a car or pickup you bus will have very minor damage. The car on the other hand will probably be totaled.
Once your bus is titled as an RV you should have no problem getting insurance regardless of your age. My bus was already titled as an RV when I bought it. I called my Farmers agent and she put the bus er RV on my policy. I did mention that it was a converted bus and she did not care. The title says RV and that is what she cared about.
busone is offline   Reply With Quote
MA Registration as an "Auto Home" bunedoggle Titles, Insurance, Registration and Money Matters 4 11-05-2017 11:23 PM
++SOLD++ 1989 TC2000 FE (Calif. CLEAN title, as "MH") chev49 Classifieds | Buy, Sell, Swap 1 02-18-2012 12:10 AM
Q. Is it illegal to drive a "school" bus in Texas? crowcalling School Bus News 8 03-02-2011 12:55 PM
What is "habitable" to , my registration story Sojakai Conversion General Discussions 9 01-23-2010 12:34 PM
