Originally Posted by Crowlp
The bus we want is in FL (we live in LA) and the owner is checking into registering the bus as an RV in FL. So, if it is registered in another state, can we insure it here in LA?
Where the bus is currently located should not be a factor.
Use a state because it is easy, or nearby.
Are you **sure** LA is that difficult?
KISS applies, start with the easiest simplest most straightforward path, maybe no heroic measures are needed.
