Old 09-17-2010, 10:43 AM   #21
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Burning Man 2010 - Metropolis
I could certainly put a door over it, similar to a fuel filler door. But the main point is, that for a camp-out like Burning Man, we need a way to monitor and ration accumulation of gray water, since we cannot dump it on the ground. And this system did the job.
Elliot
Old 09-19-2010, 02:13 PM   #22
Elliot, thanks for the report.
A thought - with a 64 gallon grey tank, and a 70 gallon black tank, maybe a cheap pump to offload some of the grey into the black for more "breathing room," if you can't set up a valve to do it by gravity? Granted, overflow of the black tank would be more critical, and you probably can't transfer the other way. But it does sound like you could extend boondocking a bit more with a careful transfer.
Old 09-19-2010, 03:00 PM   #23
Engine: 5,9 Cummins
A transfer can be done quite easily by opening both drain valves -- while leaving the drain cap on. (Assuming a standard RV outlet system.) But as you point out, the sewer tank is more important, and my only way to measure its level is to look -- or poke a stick -- down the toilet.
I have now done precisely that "stick" measurement, and the sewer tank is around 2/3 full. That was four adults and some occasional visitors for ten days. (The use of a nice toilet is a valuable "gift" at Burning Man. When camp guests start crossing their legs and ask where the nearest porta-potties are, it is really cool to just point to Millicent's built-in facilities.) 2/3 full is all I ever want to see the sewer tank, so I am definitely going to add a second 64 gallon gray tank (which I have planned on all along). Maybe even a third, though it would need to be a bit smaller to fit.
While we are on this topic.... Don't be shy with the de-stinking chemical! The label often starts by saying "4 ounces", but don't stop reading there, because the next thing it says is "per ten gallons". Also, once in use, the stuff is not effective for all that long. I started with a quart, and added a pint mid-week (on the advice of a more sensitive nose among us). I use the same stuff in the gray tank; just a bit less of it.
(A couple of years ago some friends of ours built a shower up on a flatbed trailer and drained the gray water into a barrel underneath. But no chemical. Then they asked me to carry that barrel outta there. Peeeeyooooo! But I poured a good dash of RV chemical in there, and it became stink-free almost instantly. A valid case of "better living thru chemistry"!)
All right, gotta go out and drain all this stuff. (I use the sewer cleanout next to my house.)
Elliot
Old 09-19-2010, 03:11 PM   #24
Engine: 5,9 Cummins
Here is a shot from the top of our display, with four of our Kinetic Racing Sculptures (pedal-vehicles) parked in front. The ship on the far left is a visiting motorized "Mutant Vehicle", based on a motor home chassis.
And....
View of our display from the opposite direction, during the brief rain shower we enjoyed early in the week.
Elliot
Old 09-19-2010, 08:44 PM   #25
Engine: 5,9 Cummins
There is actually a Thunderdome at Burning Man every year. Very popular. "Nerf" weapons.
Elliot
Old 09-20-2010, 08:48 PM   #26
Year: 1974
Coachwork: American eagle
Chassis: Silver Eagle
Engine: Screaming Jimmy 8v-71
Rated Cap: 46
I had 20 people and gear pulled a 32' converted RV to a trailer and 20 peoples gear and made the trip fine.Boy after everyone was loaded up my tc2000 was really stretching to hit 35mph! but once it hits that 3rd gear it's all up from there. I camped with red lightning at F and 6:30 Milicent i did see you in your kinetic vehicle around 3:00 but was just to many things at the time going on to stop and say hi. I was stuck at the gate during the sand storm white out then it started raining ..the rainbow triple rainbow was cool. I have The whole trip only "PG-13 rated" with pics and video are on my website >>>
"Thunder Bird"
Chadluc is offline   Reply With Quote
Old 09-20-2010, 09:49 PM   #27
Engine: 5,9 Cummins
Amazing what a little Cummins 5.9 can pull!
Elliot
Old 09-20-2010, 10:47 PM   #28
Year: 1974
Rated Cap: 46
I can't believe it! It cruised 55- 60 smooth and around the 10mpg mark. I never tested the vehicle under such loaded conditions before ..and it was fine...next year I guess I'll be bringing alot more people and stuff!
"Thunder Bird"
Old 09-20-2010, 11:11 PM   #29
bus-bro's Avatar
Engine: 3208 na boat anchor
Chadluc, that's truly remarkable!
Old 09-23-2010, 12:01 PM   #30
Year: 93
Chassis: ?
No kidding.....I was a little worried about pulling a small vehicle with mine(5.9 as well). Perhaps it was unwarranted. Any overheating issues?
swhite832 is offline   Reply With Quote
A Crown for Burning Man Reymac Skoolie Conversion Projects 35 08-07-2017 03:26 PM
2010 RV Rally in KY keith Classifieds | Buy, Sell, Swap 10 06-24-2012 12:35 PM
Streets & Trips 2010 POI Megafile Video Tutorial (funny) lornaschinske Everything Else | General Skoolie Discussions 1 02-29-2012 06:24 PM
2010 schoolbus Everything Else | General Skoolie Discussions 2 01-06-2010 01:24 PM
Let's talk Burning Man. Who's Burning? Branden Everything Else | General Skoolie Discussions 2 08-21-2005 05:00 PM
