08-08-2016, 12:34 PM
Can you paint the rubber flooring?
We have a crown bus (this was a Mine Bus, then a church bus prior to us getting it) ... we have several places that have access to things like air lines and radiator lines. This has to be left as is to keep access. Our flooring is in excellent shape but I was wondering if it would be possible to either paint it or coat it in like an elastameric roof coating? Any suggestions welcome. If I didn't have to leave the 15'' open the whole length of the bus and 2 other access points I would use laminate flooring.
Also considering the laminate tiles and cutting and piecing the opening's to keep the access.
08-08-2016, 12:47 PM
Rated Cap: 37,400 lbs GVWR
I plan on laying either bamboo flooring or PVC tiles over my Crown's original Armstrong rubber flooring. The rubber is only about 1/8" thick, so you won't gain any appreciable headroom by taking it up. You may however want to remove the curved coving along the edges to make it easier to fit furniture/cabinets/etc - there's a strip of curved steel under the rubber that's screwed into the wall and nailed to the floor, not easy to remove! Whatever I do, I'll keep my floor hatch that provides access to the fuel tank (I have a RE bus).
What model and year is your Crown?
08-08-2016, 12:58 PM
1980 all the title says is bus for model on the title.
08-08-2016, 06:23 PM
Chassis: All American RE
for whatever it is worth.... we have a few areas on the rubber floor at the bus entrance that we spilled some metal paint on.... about 5 years ago. Still sticking to the rubber perfectly.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
08-08-2016, 06:31 PM
Oui!
08-08-2016, 06:52 PM
A voice inside said "Brother you can paint anything you want to!"
08-08-2016, 07:00 PM
..... The question is... Whether or not it will stick!
Guess the same principle applies to lawsuits
08-08-2016, 08:35 PM
Originally Posted by milkmania
Oui!
exactly. lol
Ryan
08-09-2016, 06:40 AM
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
My nephew painted his atv seat. Now every time he rides there is red paint stuck to his jeans that will not come out.
08-09-2016, 06:42 AM
Thank you!
08-09-2016, 07:02 AM
Thank you all for your input. I decided to try the cool coat on a spot that came up and will be hidden under the bed. I will do a few coats and let it dry a day between. Then hit it wwith a Pressure washer. I also talked to a local paint store who says they can tint it also
08-09-2016, 09:21 AM
My neighbor back in the 80's was a meth head and he painted his shag carpet with water based latex paint.
08-09-2016, 10:14 AM
Rated Cap: Your mom +1
That there is a winner...
