Old 08-08-2016, 12:34 PM   #1
Question Can you paint the rubber flooring?
We have a crown bus (this was a Mine Bus, then a church bus prior to us getting it) ... we have several places that have access to things like air lines and radiator lines. This has to be left as is to keep access. Our flooring is in excellent shape but I was wondering if it would be possible to either paint it or coat it in like an elastameric roof coating? Any suggestions welcome. If I didn't have to leave the 15'' open the whole length of the bus and 2 other access points I would use laminate flooring.
Also considering the laminate tiles and cutting and piecing the opening's to keep the access.
SuedrivesTRKs is offline   Reply With Quote
Old 08-08-2016, 12:47 PM   #2
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
I plan on laying either bamboo flooring or PVC tiles over my Crown's original Armstrong rubber flooring. The rubber is only about 1/8" thick, so you won't gain any appreciable headroom by taking it up. You may however want to remove the curved coving along the edges to make it easier to fit furniture/cabinets/etc - there's a strip of curved steel under the rubber that's screwed into the wall and nailed to the floor, not easy to remove! Whatever I do, I'll keep my floor hatch that provides access to the fuel tank (I have a RE bus).
What model and year is your Crown?
Old 08-08-2016, 12:58 PM   #3
1980 all the title says is bus for model on the title.
Old 08-08-2016, 06:23 PM   #4
syke's Avatar
Chassis: All American RE
for whatever it is worth.... we have a few areas on the rubber floor at the bus entrance that we spilled some metal paint on.... about 5 years ago. Still sticking to the rubber perfectly.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 08-08-2016, 06:31 PM   #5
Oui!
Old 08-08-2016, 06:52 PM   #6
Carytowncat's Avatar
A voice inside said "Brother you can paint anything you want to!"
Old 08-08-2016, 07:00 PM   #7
..... The question is... Whether or not it will stick!
Guess the same principle applies to lawsuits
Old 08-08-2016, 08:35 PM   #8
syke's Avatar
Originally Posted by milkmania View Post
Oui!
exactly. lol
Ryan
Old 08-09-2016, 06:40 AM   #9
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
My nephew painted his atv seat. Now every time he rides there is red paint stuck to his jeans that will not come out.
Old 08-09-2016, 06:42 AM   #10
Thank you!
