Old 09-19-2017, 09:12 PM   #1
bigskypc50's Avatar
Engine: DT466 Turbo
Rated Cap: 90
Road trip MT to NM I-15 or I-25
Greetings everyone taking my bus on a huge maiden voyage will be driving from Butte,MT to ABQ,NM around the 1st of October.
Of those who know the route well would you take I-15 or I-25, looking for the one with the least amount of pass's and what would be the easiest drive that time of year. Google shows both, one is like 100 miles longer but I-25 I like much better straight shot on down south, but worry about big hills and mountains etc
bigskypc50 is offline   Reply With Quote
Old 09-19-2017, 10:21 PM   #2
turf's Avatar
i've driven Butte to Denver a number of times and Denver to Albuquerque a few too. i can only think of 3 hills.
the toughest hill is right at Butte and again Cardwell. the third big one is Raton pass, but it is long straight fairly easy grade.
i havent done I15 south in a long time. i remember it being a 2 lane highway but maybe thats changed over the years.
Denver traffic is the biggest obstacle on I25
i want to move back to the area - i grew up around p-berg / drummond
good luck!
Turfmobile Build Thread
Old 09-19-2017, 10:35 PM   #3
Engine: Cummins 6BTA 5.9
I agree about Denver traffic being the biggest obstacle on I25. Raton Pass is no problem.
PossumLiving is offline   Reply With Quote
Old 09-19-2017, 10:41 PM   #4
bigskypc50's Avatar
Engine: DT466 Turbo
Rated Cap: 90
Thanks for the feedback, you must have spend many summers at g-town lake. I love going up to storm lake.
Not to worried about traffic I am giving my self plenty of time 3 days. I am running heavy and want to avoid any huge pass's I have done homestake pass twice in the bus it not too bad. Dropped into 3rd and crawled up but that was pre conversion.
good luck!
Old 09-19-2017, 11:25 PM   #5
Chassis: Blue Bird
Engine: ISC 8.3
I can tell you that I-15 through the northern half of Utah (say, Tremonton to Scipio) is tame so far as elevation is concerned. I've only driven it as far north as Idaho Falls, though not very often, but it seems the only notable southbound climb is heading into Malad. I can't say anything about southern Utah toward New Mexico.
We've had our first snow storms the past couple days bringing snow down to maybe 8000 feet, but that's well above I-15 here. We'll probably warm up again, at least a little, in the next two weeks.
Old 09-20-2017, 04:13 AM   #6
tobeamiss's Avatar
Congratulations on your Maiden Voyage good luck and Happy Trails!
oh yes she did!
http://www.skoolie.net/forums/f11/to...-it-16557.html
Old 09-20-2017, 08:10 AM   #7
turf's Avatar
i logged around georgetown lake back in the 80's. now its a bunch of condos on the lakeside back on the section we worked.
Old 09-20-2017, 09:21 AM   #8
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Howdy bigskypc50! I grew up in Helena.
Since you are from the west and understand hills… I-90 -> I-25 is very easy (as noted). From Butte, there are no scary hills (Bozeman Pass, Raton Pass). I-15 is much more interesting (in my opinion) but it does offer a few challenges and there are lots of neat highways to use to cut down/across. However; it takes much longer and is much more of an adventure. Sounds like you are not looking for that kind of adventure.
Denver, in my opinion, is best driven straight thru during the off hours (middle of the night). The 'problem' that it seems to present is lots of traffic moving fast (for about 100 miles) which often becomes kinda overwhelming.
I don't think weather will be an issue that time of year (certainly not south of Colorado Springs) but do keep an eye out for an early winter storm anyway.
Are you heading south for the winter or going to see the balloons?
JD - Full timer out west
My Adventures & Build
Old 09-20-2017, 10:29 AM   #9
bigskypc50's Avatar
Engine: DT466 Turbo
Rated Cap: 90
I was just up in Helena doing a trip to Home Depot last week, I like Helena.
Ya I am just looking to get down to NM with the least amount of excitement as possible. So it sounds like I-90 to I-25 is the way to go.
I am staying on a buddies land in southern NM but I won't be ready to move until early next year, so thought I would move the bus down to ABQ and get it close and out of the freezing cold Montana. Where an unheated bus in 25 below 0 would likely mess up my floors and walls etc.
I am like 10 days out from my trip and it looks like the temps will stay in the 70's all the way down. It's in the low 20's here now and was thinking the rest of the route was that cold. Not thinking very well.
Old 09-20-2017, 11:37 AM   #10
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Very kewl! I'm currently at 8000' near Grants, NM. Overnight temps are in the high 40's (though the 30's are coming fast), daytime highs in the mid 70's. Warmer down at the typical 4000'-5000'.
I have not worked on bus heat yet either. I'll likely spend the winter in NM at the state parks down south ($5/night for electric with annual pass) (Truth or Consequences, Deming, etc) so I can use electric heaters during the cold period (end of Dec, part of Jan but varies). The temps over near Yuma/Parker/Lake Havasu AZ are always pretty reasonable though they often have a cold spell (same time period). The elevation is very low there which helps tremendously.
