05-27-2017, 12:37 PM
Chassis: Express 3500
Engine: 6.5L GMC Diesel
Rated Cap: 24
03 Chevy - AK Shortbus
Hey all,
Wanted to take a moment to introduce myself and my bus "Martin" to the skoolie network! Martin is a 2003 Chevy short bus with a 6.5l GMC diesel engine. I was stoked to find a diesel bus as he gets around 16mpg on the highway (will be even higher when I put a chip in!)
I got my bus in New Jersey sight unseen from a Gov surplus auction for $1,000! With help from family living in the area I flew to NJ from Washington, picked up the bus and got a temp plate from the NJ DMV.
I then began the 3,000 mile journey back to Washington through the I-90 corridor, travelling through Chicago, Wisconsin, South Dakota, Montana, and Idaho along the way. I had to be back at work after a 3 day weekend so this whole drive had to fit in a pretty tight timeframe! All went well, minus being pretty hagard after driving 3,000 miles in 3 days. I was so happy to find out that the bus ran strong with rust being the biggest issue I'll have to address (East Coast bud - to be expected).
After a few more weeks at my winter job in Washington, Martin and I drove to Alaska where I'll be working for the next 6-7 months. The drive went smoothly, going up through highway 1 into BC and eventually joining up with the Alaskan highway around Fort St. John. We made it to Southeast Alaska in 4 days and with only 1 snowstorm along the roads. Drive was in March - my posting is a bit delayed ;)
Now that we've made it up here I'll settle in to my summer work and work on converting the bus on my weekends.
More updates to come as I make progress.
05-27-2017, 01:07 PM
You're certainly putting some miles on Martin. The Alcan sounds like a fun trip. The drive back from NJ, not so much. Glad to hear things went well on both trips.
Robin
Nobody's Business
05-27-2017, 02:04 PM
Rated Cap: 24
Thanks Robin! It was quite the journey to get it westward and then to the North. With 127,000 miles on the bus when I picked it up I have a feeling this diesel will see me through many miles in the coming years.
05-27-2017, 09:48 PM
Rated Cap: 24
Got a bed platform installed in the back and put some reflectix foil insulation in the back windows by the bed. Really cut down on draft and made it a whole lot warmer in there!
I also forgot to mention earlier that the bus came with all the seats out except 1 bench. Real happy not to have to deal with removal/disposal!
05-28-2017, 12:03 AM
Rated Cap: 24
06-10-2017, 05:11 PM
Rated Cap: 24
Everything must go!
Well, even though I moved in temporarily and built a bed platform, I used my weekend to get everything out and into storage before gutting the floor and walls.
I often travel to the mountains/snowy places so getting the cheap bus insulation out and putting some higher R-value foam board in there was a must. Luckily its summer in Alaska (which is actually pretty warm) so no need to worry about freezing for now.
As of this update I have all the wall and ceiling panels off in the "back" living space, front cab will come later. I used some Phospho and a spray bottle to treat the floor for rust after grinding away some of the worst spots. All in all I'm considering myself quite lucky as the floor only has a few spots of rust.
This step will be great as the Phospho turns rust into carbide and will offer a lasting fix alongside the rustoleum paint I'll be putting down in a few hours.
More updates to come as I move into framing and flooring the bus.
Cheers,
Charlie
06-10-2017, 07:18 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I've already survived two Montana winters in mine, but I have a lot more cubic footage to heat. My best suggestion? Get some German Federbett comforters and plenty of blankets. http://betten-anne.de They ship to the states, usually within a week of your ordering them. Prices are in Euros, so if you use PayPal, it's a no-sweat conversion.
06-10-2017, 11:54 PM
Rated Cap: 24
Those blankets look pretty nice, my girlfriend bought me some Pendleton blankets (super cozy and warm). Since its summer I have coughed up the money for a heating unit (prioritizing other purchases) but I plan to get a diesel heater and store near the back of the bus in a spot I'm building at the end of the bed. Since the bus runs on diesel I figure I'll always have some fuel nearby
Where do you winter in MT? I used to live in Big Sky (pre-bus) and it get's wicked cold in December. Kudos for making it work, I'm striving to get this thing as ready as it can be for next winter!
06-11-2017, 06:33 AM
forget blankets and bundling up.. put in a H*LL of a furnace and stay nice N warm!
seems alot of have success with wood stoves boilingthem out of their bus in cold winters.., in alaska theres like endless firewood isnt there?
06-11-2017, 10:11 AM
Rated Cap: 24
I'm going with diesel heater since the bus is fueled by diesel. I thought about wood stoves, and as you say a lot of Alaskans heat their homes with wood stove primary backed up by a toyo diesel (toyo to keep your home at 50 deg. while you're away in the winter). There are two reasons I'm opting against the wood stove for the bus:
1) The stove itself is typically heavy and eats up precious space in this small bus.
2) The wood fuel needed isn't available everywhere, and requires lugging around lots of firewood (extra fuel source that is only good for 1 thing whereas diesel will work for the bus and the heater).
I've also talked with a few people around my neck of Alaska who have converted skoolies who have told me its hard to finess the heat level of a woodstove in such a tiny space. Like you said you typically get burned outta there!
06-11-2017, 10:15 AM
Rated Cap: 24
Floor going in
I stayed up late last night getting the floor framed out and putting in the first sections of insulation. Its coming along well and now I'm getting to the fast part. Used up the last little bit of my weekend, but should be in a good place to keep chipping away at this after work each day.
06-11-2017, 04:55 PM
Chassis: HDX
Engine: Cat C7
Pendleton blankets are superb! I'm in Billings (the BIG city). Rent in this town is obscene! What you can afford isn't worth living in and what you'd like to live in you can't afford. So, after Dad died, with my share of the estate, I shelled out $8K and bought Brunhilde. Drove her here from Kankakee, IL, paid two kids $340 to strip the seats, laid out $700 for carpeting and lino, $300 for a custom bedframe and she's become a work in progress.
06-11-2017, 08:40 PM
A good sleeping bag will keep you warmer than blankets in cold temperatures. Have you seen the Cubic Mini or the Dinkinson wood stoves?
06-12-2017, 10:33 AM
Rated Cap: 24
Joyce, I have seen some pretty rad "sardine can" wood stoves that don't take up too much space. It just comes down to having to lug around a bunch of firewood (which is also a problem crossing to/from Canada) and the ability to regulate heat.
I think the diesels do a great job, you set the temp you want them to maintain and they do the rest! Besides, I'll be carrying a couple gallons extra diesel fuel for the bus, if the heater runs out I'll have that covered too.
I have a -20 deg. sleeping bag that definitely came out this spring as I was driving the bus north to AK in March
06-14-2017, 04:58 PM
I am planning to get a Cubic Mini when I start kitting out my dream bus. I'm hoping that burning those bricks of sawdust that you can buy at various gardening centers and box stores will keep the state line Firewood Nazis off my case.
06-14-2017, 05:56 PM
The hippies in the sixties would get the smallest stove they could find and often burned about three charcoal briquettes at a time in an insulated bus. Most wood stoves are kind of intense for a bus.
Robin
Nobody's Business
