Old 12-17-2014, 09:07 AM   #21
Re: 1934 Wayne Daysailer
Pretty Wild! --- Haven't seen that construction method before. And I notice you are labeling all the parts. Gonna be a fun puzzle to put back together.
BTW...have you located an appropriate nose for that darlin' yet?
Also...if you are any other vintage Chevy folks need any 20 x 5 original rims...I have a stack of them that have to go.
Old 12-17-2014, 11:35 AM   #22
You are a man after my own heart--you are doing it the way it ought to be done! Toooooo much fun! Jack
Old 12-18-2014, 10:57 AM   #23
Year: 1934
Chassis: 1936 International
Yes - I have the '36 International nose already. I found a complete body less frame. In retrospect, it would have been much better to have the frame since the frame establishes the position and shape of the all the body parts - fenders most importantly.
Daysailor is offline   Reply With Quote
Old 12-20-2014, 01:41 AM   #24
Cool bus, lots of potential, I'll be watching.
https://www.skoolie.net/forums/showthread.php?t=9883 - 7.3L 4x4 Shuttle Bus Toyhauler conversion
headinthetrees is offline   Reply With Quote
Old 12-20-2014, 09:26 AM   #25
Congrats on the find! --- Looks to be in pretty darn good shape.
Old 03-13-2015, 12:29 AM   #26
Year: 1934
I've been busy (2 hours a week) working on the new chassis for the '36 International. It's going on an '88 Suburban (sweet old rigs and a dime a dozen). Turns out that the hump in the frame over the front axle is the exact same height as the high point over the rear axle - so that establishes my floor height. The axle is much further forward in old rigs than modern ones and after some consideration, I decided it was easier to move the engine back instead of moving the axle forward. The engine is now back 12-3/4" and it's time to establish wheelbase and floor structure.
IMG_20141206_134046_399.jpg   IMG_20141214_150415_633.jpg   IMG_20141230_174854_632.jpg   IMG_20150102_073253_863.jpg
Old 03-13-2015, 12:37 AM   #27
Year: 1934
Details on moving the engine. I built super structure to relocate the OEM crossmember and engine mounts back in the frame. I think the hotrodders usually weld mounts, but I kept with the OEM theory and bolted it all in. The plywood pic shows where the new floor will be.
IMG_20141230_174836_101.jpg   IMG_20150124_153733_159.jpg   IMG_20150308_122309_910.jpg   IMG_20150308_140429_860.jpg
Old 03-13-2015, 09:46 AM   #28
Outstanding! --- starting with a functional chassis does give you quite a leg up. There are plenty of times I have wished I'd done the same instead of building all new systems onto my old frame.
Can't wait to see more.
Old 03-14-2015, 09:20 AM   #29
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Very cool! A shop that size is always a plus.
Old 03-14-2015, 09:21 AM   #30
This will be a fun build to watch!
63 Wayne/International 63Wayne Conversion General Discussions 12 10-01-2017 10:56 PM
ya' say you like Wayne buses?? gusbus Everything Else | General Skoolie Discussions 11 03-14-2015 09:37 PM
First Timer, 92 Wayne 7.3 grnthmb55 Skoolie Conversion Projects 29 05-14-2012 10:22 PM
91 International Wayne Diesel Dan Conversion General Discussions 2 02-18-2010 01:03 PM
Gypsy Wayne 5gypsykings Skoolie Conversion Projects 2 09-28-2009 04:26 PM
