Old 01-25-2013, 12:36 PM   #31
the_inevitable's Avatar
Year: 1973
Coachwork: Chevy
Chassis: Step Van
Engine: Chevy 350
Re: 1973 Chevy Step Van Conversion
We're still here!
Got the floors all down, putty in, sanded, and stained. I really like how the grey stain came out, especially after a few layers of poly.
After poly. This does not do it justice at all, but that's what we got for always working on it at night.
End desk going in, seat back in, and the very nice white edging that Allie fabricated and installed to cover up the edge of the flooring.
Edging on the other side.
Cabinets starting to go in. Power box hides under the large piece next to the wheel well.
Everything cut in to the waste tank. Scary cutting in to that expensive piece of plastic.
Power is hooked up and tested. AC works, 12V system works, no issues in wiring.. big success
With the seat back in, we took it for a spin around town and it still handles like a dream.
We've got plumbing down, but have one last question - we need a piece of 3" pipe to run from the outlet of the tank to the output to the outside where the gate and everything is. It'll be about 2 or 3" long max. I can't find ABS at all... is it okay to just use PVC and silicon caulk the crap out of it (put it all around slide it in, put more on the outside) or am I asking for a leak? I'd rather cement it in, but PVC and ABS no like each other.
Thanks for looking and thanks for all the help!
See the amazing adventures or whatever at http://travel.vcprod.com
the_inevitable is offline   Reply With Quote
Old 01-26-2013, 10:01 AM   #32
Hey Guys --- I'm in the same boat. Just need a couple of feet of ABS pipe. Here is what I found as probably the best deal here locally. The Depot...
http://www.homedepot.com/buy/vpc-3-i...l#.UQP9d_Kbmzk
Old 11-12-2014, 05:39 PM   #33
any 'finished' pics??
longhaul is offline   Reply With Quote
Old 11-12-2014, 07:41 PM   #34
Home Depot sells a combo glue that is made to glue ABS and PVC together. I used it on my bus project and it works just fine. You will find that in time, silicone sealer fails to stay bonded to either ABS or PVC though sometimes there is no choice. In those cases a split collar and a stainless steel hose clamp helps the system last longer--best to avoid the problem if you can.
Old 11-13-2014, 10:51 AM   #35
Hmmmm, Something very odd here...the post above with the pipe was NOT put here by me...Tango. What's up with that Moddies?
Old 10-12-2015, 05:38 PM   #36
Update?
Surely there is more to report! I am starting my own project, and eagerly await more.
Thanks!
RG
Kurbmaster is offline   Reply With Quote
Chevy Step Van (not a bus, exactly) Black Water Problem the_inevitable Short-Bus Conversion Projects 17 01-15-2013 01:11 PM
1985 Chevy P30 SchoolBus Conversion TygerCub Short-Bus Conversion Projects 13 12-21-2009 08:10 PM
Is there a step by step How-to guide for replacing windows? crazycal Conversion Tutorials and How-to's 1 03-06-2007 06:58 PM
eBay Chevy School Bus Conversion Steve Classifieds | Buy, Sell, Swap 1 06-20-2005 10:22 AM
1984 Chevy / Wayne conversion glock17 Skoolie Conversion Projects 29 05-10-2005 07:54 AM
