Old 01-16-2008, 09:49 PM   #21
swinada's Avatar
Re: 1985 Blue Bird 'Micro Bird'
you probably don't have a shut off valve on your rear heater, which is fairly common. Get yourself a few hose connectors, they look like this and a few feet of hose. (2 pieces, one to loop the hoses and one to loop the heater itself) with a cold engine remove your radiator cap to release any pressure. Leave the cap off, remove the hose clamps from your heater connections, now remove the first hose (it might be baked on there due to time-heat etc. and be easier to cut off then pull off, what helps to pull it off is warming the rubber up first with a heat gun, hairdryer, torch or what ever you have.) and quickly connect the extra pieces of hose and hold it up. (make sure you got the right size )You want loose to much fluid if you hurry up. maybe have a second pair of hands handy. Remove the other hose and connect the two. Now remove or move your "hated heater".
If you wanna get rid of the heater all together, just loop from one inlet to the other in your engine compartment. Looks like you could just use a hose connector and some hose clamps on these 2 hoses.
I would not worry about removing the hoses under the truck, just loop them together too, then they are there and ready to be used again if you decide down the road that you do need a heater.
Tip: if you park your Bus on a downhill slope to do this procedure your heater in the back will probably be higher then the radiator and you want loose that much fluid.
When all done fill your rad with 50/50 (thats for us in the cold Canadian north, you might be ok with 75/25 mixture) water / antifreeze and tighten the radcap, fill the expansion container to the cold line and start your engine. Check for leaks. after the first drive you might need to refill some antifreeze mixture.
Good luck and happy converting.
add on: the most fluid loss will be coming out of the heater core, so if you are able to remove the bolts that hold the heater do that first. make sure you got them all so that the heater is free to move. Then when you disconnect the hoses simply put the heater on its back so the inlets are facing the ceiling.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 01-16-2008, 09:57 PM   #22
the_experience03's Avatar
A pair of radiator hose pinching pliers will go a long ways. They will clamp off the line and save you from getting leaks without doing damage. Mine are Snap-On, but I know there are cheaper ones out there.
These are $23.70 on Snap-On's website....
Old 01-16-2008, 11:13 PM   #23
Originally Posted by ShortBus
experience03, I truly appreciate your guide to the leaf springs, but I don't think it's something I can do myself.
I'd do it for you if you lived closer, but that's not the case. Convince my boss to give me a weekend off and I'll come do it for you. How about that?
I'm thinking about bringing the bus into my mechanic sometime this spring so he can look the whole thing over and give it a tune-up. He works for about $20/hr which isn't too bad for mechanics these days (most of the ones around here are $60/hr+.) Perhaps I will get a quote from Husky Spring and compare the two, thank you for the recommendation!
It's a good idea to have your guy do it. Husky Spring is capable of doing the swap for you, but just have your guy do it. However, you're going to need new springs and Husky is still a great place to source them from. They will ship them if you want. I just can't imagine that the springs will be cheaper from a dealer or parts store. Like I said before, they can rebuild your current pack as well. Every leaf they reuse is a few bucks less you have to spend.
I definitely want to get rid of the heater all-together, if it would have been a normal seat it would be in the junkyard as we speak. Where do you guys think a good spot would be to disconnect the hoses at?
I'd just do it under the hood. The less extra plumbing you have the better.
Why would I need to buy a few feet of hose if I'm just looping the hoses already there together, wouldn't one hose connector and two clamps be all I'd need, or am I missing something? Equally stupid question: are the radiator hose pliers supposed to be used to pinch a hose while you're cutting it, if so would it be better to have two of them?
Yes, you could probably get away with just one fitting. Just make sure the hoses don't collapse. A pair of those pliers would be ideal. Regular vice grips also work well. Just wrap a rag around the jaws to keep them from damaging the hose. I just really like the pliers I have, but it might be tough to justify the cost for a one time deal. I'm using mine all the time.
Old 02-24-2008, 06:59 PM   #24
I just looped mine together. Being that you are removing it in the engine compartment why don't you just remove the hoses as well? The coolant level will drain down when you disconnect in the engine compartment, but I'd still expect to see some of the green stuff inside too. It's just nature of the beast. Some towels will make short work of it and ethylene glycol is water soluble so you can just clean it up with a wet rag. It will not leave a mess.
On the other hand you could leave it connected in the engine compartment and then just loop it in the passenger compartment. This is what I did knowing that I would like to add hydronic baseboard heaters or some other heat source based on engine coolant at some day. Heck, maybe I could even tie it into a boiler that would serve as a block heater of sorts as well.
Make sure you top off the cooling system after you do the surgery. Run the engine long enough to get up to operating temperature with the radiator cap off. It's going to bubble out the air, but eventually the thermostat is going to open. When it does you will see coolant pumping out and getting ready to geyser out of the fill tube. Screw the cap back on, turn off the engine, and top off the overflow tank. Best of luck.
Old 03-11-2008, 08:59 PM   #25
The cap turns that first half a turn to a pressure release position. To actually remove it you will have to push down on it fairly hard and continue turning. Sometimes they can be a real bear, but it should come off. The overflow tank really isn't going to do you much good when it comes to bleeding that thing out. When I was talking about bleeding basically I was just saying that you are going to want the whole system filled. Air makes a pretty poor coolant in a water jacket.
Old 03-11-2008, 10:49 PM   #26
I used the barbed style plastic fittings to do mine, but the factory used copper fittings to connect the rubber hoses for what it's worth.
Old 03-14-2008, 03:34 PM   #27
lapeer20m's Avatar
also handy in the summer on long hill climbs when your engine begins to overheat. Turning on both heaters inside the bus will help remove a lot of heat energy from the motor.
Old 03-14-2008, 05:26 PM   #28
phillbus914's Avatar
In the meantime, does anyone have any advice for safely clipping the wires going to the old heater?
As long as the fan's are off (turn the ignition off to be safe) the wires wont have any power going to them. Just clip them and put electrical tape on the ends (where you see bare wire) then if you accidentally turn on the rear fans nothing will happen. I'd leave the wires in place.. down the road if you ever wanted something 12volts back there (fan, light, ect..) you already have wires & switches to run it.
12Volts wont hurt ya anyway. It's not like handling live 110 (house) wires. Worse thing that'd happen if the wires were live and you cut them is if they touch metal (ground) they'd spark and blow a fuse or ckt breaker.
Also both wires are most likely + wires (one for low and one for hi) the heater usually grounds through the body of the bus. Thats how my bus was, I found that out when I mounted my heater in my wooden closet and the fans didn't wok.
My Old Bus :(
Old 03-14-2008, 11:49 PM   #29
I can't tell you specifically what's going to work on your floor other than a lot of elbow grease. It's tough work, but I'm sure you'll find a trick.
As far as painting the floor the only option really is to roll it on. I spot painted a few parts of my floor with a spray can and even that was tiring and expensive. The roller was so fast and left a really nice coat. I didn't actually use Rustoleum, but rather an industrial oil based metal primer. It was cheaper than Rustoleum and has held up great so I can only surmise that there is no need to pay the extra for the "professional" stuff.
Old 03-31-2008, 10:36 PM   #30
Engine: 5.9l Diesel Cummins
Rated Cap: 20
Looks like the floor coating went down well. Are you going to caulk the holes in the floor? What about the metal skin under the windows, are you going to peek behind there for rust? Just asking because I am just to be on the safe side.
Re your heater, I'm not sure what you could get from it, maybe call your local auto salvage yard??
My 1997 Ford / Thomas shorty
5.9l Diesel Cummins w/automatic tranny
Photo's of my bus build
Billsman is offline   Reply With Quote
Old 04-08-2008, 11:12 AM   #31
TKFT's Avatar
Year: 1983
Engine: Chevy 350 V8
Rated Cap: 20
How do I go about cutting/removing them without getting shocked or anything?
I would say just disconnect the battery before you cut them so there is no risk of shock.
My Bus:
1983 Carpenter Cadet CV
TKFT is offline   Reply With Quote
Old 04-08-2008, 02:22 PM   #32
lapeer20m's Avatar
there is zero risk of shock....unless you touch the wires to your tongue.
You can wet your fingers and touch both terminals on a bus or other automotive battery and you will feel nothing. 12 volts is completely harmless when it comes to electrocution.
somewhere over 40 volts electricity becomes dangerous to humans.
Old 10-15-2008, 06:21 PM   #33
Year: 1961
Coachwork: GMC
Chassis: SDM 4501
Engine: 6V71
Rated Cap: 45
I just joined this site a few days ago, and given that it is now October, my guess is you have figured out the caulk removal! I am getting ready to start my own conversion project in the near future and I have had similar questions that you have raised. I've learned a lot just in the few days that I have been reading the blogs on this site. Great info! Thanks to you and all of the other helpful members!! Do you have any recent pics of the progress on your shorty?
Zcommanager is offline   Reply With Quote
Old 07-08-2009, 01:28 PM   #34
artistik1n's Avatar
Engine: v8 350
Any updated pics to you bus? I was curious about your setup with the booth/bed, I want to see if it became of it.. I was thinking of doing the same in my bus, seeing as how we have very similar buses?
artistik1n is offline   Reply With Quote
Old 07-21-2009, 01:35 AM   #35
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
On Saturday I had to run my stock car to the muffler shop that sponsors me in Cloquet and stopped at Wal-Mart on the way back to the race garage when someone recognized my hauler in the parking lot. It was nice to meet a fellow skoolie Shortbus. I hope you get your transportation issues solved so you can get back to working on the bus. Hopefully my bus is a little cleaner next time I run into someone but I have been so busy working on the mechanical things and cosmetics that I haven't had a chance to clean the inside since May.
Firearm is offline   Reply With Quote
1985 Chev Bluebird Micro Bird Bus skybluefreeway Short-Bus Conversion Projects 9 06-25-2020 12:00 PM
1985 Blue Bird Motorhome mike jacona Classifieds | Buy, Sell, Swap 11 08-22-2011 07:04 PM
1985 Blue Bird PT36 Steve Coach Conversion Projects 44 07-20-2011 12:29 AM
Micro Blue Bird engine... spoonman Conversion General Discussions 13 09-02-2010 04:35 PM
1985 GMC Blue Bird (Bob) SamW Skoolie Conversion Projects 10 11-23-2006 07:38 PM
