Old 11-26-2008, 10:17 AM   #1
Engine: 7.3 diesel
Re: 1985 E-350 giving us some trouble
Did you have any good luck yet on getting going. If there was reworking done to the fuel system I'd be looking for kinked fuel lines along with what was stated already.
If you have a diesel which I'm sure you do with a return fuel line you could be looking at an injector pump that may be leaking. That is often seen with fuel going into the oil. Other thought that comes to me is how is the weather outside? If it is cold enough and you still have #2 diesel fuel in the tank that may be a problem. A bottle of "diesel 911" would help at that point. It is a red colored bottle.
Please do let us know what comes out of this.
Old 12-02-2010, 08:53 AM   #2
Stuff's Avatar
says V-6 in his info. Id look to see if there is kinks in the lines or something.. maybe add a filter etc.
Battery monitor giving false load readings mrkos67 Alternative Fuels | Electric, Propane, Wood & Biofuels 3 09-29-2014 06:16 PM
Brake trouble jolly_rogger Ford Drivetrain 1 06-07-2011 03:23 PM
Trouble ulaff Skoolie Conversion Projects 7 09-13-2010 05:30 PM
Trouble starting after conversion Diesel Dan Alternative Fuels | Electric, Propane, Wood & Biofuels 0 08-19-2010 04:51 PM
Why me? Radiator trouble! J.B. Classifieds | Buy, Sell, Swap 0 05-05-2004 08:53 AM
