Old 02-06-2013, 11:38 PM   #1
Re: 1988 30 passenger E350 El Dorado
Good lookin' rig! --- And Welcome. Really like the big rear door. Will no doubt come in handy. Had an old Toyota Odyssey that had leaking air shocks. Only cure was replacing them and the lines.
Old 02-07-2013, 01:46 AM   #2
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Spray bottle with soapy water should help you find the leak.
I'm hungry!
You Gotta Let Me Fly
Old 02-07-2013, 11:33 AM   #3
Just a thought...but if you already have an onboard compressor for air shocks, you might look into replacing them with air bags. The modern versions are remarkably stout and often cost less than shocks. If mounted on all four corners they can also be set up to level the unit when parked. After much research and discussion, that is the route I've decided on for my Shorty. And like shocks, the ride can be adjusted to suit the load.
Old 02-09-2013, 09:10 AM   #4
Dwise --- Air bags are fully adjustable and the pressure can be dialed in to smooth out the ride just as air shocks can. They also have the benefit of a much wider range of adjustability yielding the added benefit of functioning to level a vehicle at rest within certain limits. Nice when the ground you are parked on is less than perfect. The new generation bags are incredibly stout with a great deal more reinforcement and the better units feature all metal end caps where the older style are plastic and less durable. I was suspect of them myself until I did some research and talked to a few owners. They seem to pretty much all love'em. I'm going with them all around and using a full four way valving system so each can be independently adjusted.
Old 02-09-2013, 04:53 PM   #5
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
hehe paint job looks like what mine used to look like!
Old 02-10-2013, 08:35 AM   #6
Ferenzy's Avatar
Coachwork: Eldorado
Chassis: E350
Engine: Ford 7.5 liter Gas
Rated Cap: 29
The body looks to be in good shape. Do you have any pics of the inside? My bus is similiar and 1990, I found tons of rust under the floor and lots of leaks from around windows and such.
Ferenzy is offline   Reply With Quote
Old 02-10-2013, 11:44 AM   #7
Rated Cap: 47
Saw that on craigslist. Congrats!
Motobus is offline   Reply With Quote
"The Bondo Condo" - 15-passenger E350 Shorty Steve Short-Bus Conversion Projects 73 04-13-2015 11:37 AM
Tailgate Nascar Special 1988 Blue Bird 66 Passenger garbemi Skoolie Conversion Projects 1 01-25-2013 05:28 PM
Any clue what Hitches would fit an El Dorado THOR bus? wirelessguyNY Short-Bus Conversion Projects 4 09-03-2011 10:04 PM
Want to convert a 1990 El Dorado 29 passenger to tour bus bluesbaby1980 Skoolie Conversion Projects 0 12-31-1969 07:00 PM
