Old 04-07-2013, 04:21 PM   #141
Charley's Avatar
Coachwork: Eldorado
Chassis: Econoline
Engine: 7.3L Powerstroke Diesel
Rated Cap: 20
Re: 1995 Ford Eldorado Shuttle bus
Originally Posted by 91 Bus Guy
If you are talking about the missing part around the wheel cut out, we called them fender flairs. I'm sure they have many names. When you search, use different words to find your product.
Good luck with your search,
Keith
Yes sir ! !
That's the part I was looking for.
Fender flairs.
Thanks Keith !
I am now on ebay to find myself a wheelchair lift because I think that I am going to disassemble the ramp of the bus.
I have found one in Germany for the price of 530,00. (688.92 USD)
http://cgi.benl.ebay.be/ws/eBayISAPI.dl ... 1114495377
I think that my 1996 Harley ,Fat Boy is too heavy for that lift.
Onley 312KG (about 687.83 lbs)
Greetings
Charley
Charley is offline   Reply With Quote
Old 04-07-2013, 04:25 PM   #142
Charley's Avatar
Coachwork: Eldorado
Chassis: Econoline
Rated Cap: 20
Originally Posted by roach711
Never mind - I'm looking at the wrong missing piece.
LOL
Maybe I have not wrote it down correctly .
Next time I will try to say it better.
Sorry about that but thanks for your answer my friend.
It could be possible that is was the mud flap
Greetings
Charley
Old 04-07-2013, 05:16 PM   #143
91 Bus Guy's Avatar
Chassis: Chevy G30
Engine: 5.7 V8 TBI GM
Rated Cap: 10
Send a message via MSN to 91 Bus Guy
Originally Posted by Charley
Yes sir ! !
Fender flairs.
Thanks Keith !
You're welcome Charley, My PO used the chair lift in my bus to load his Harley. Worked well for him.
Here is a pic of the lift when he used it.
That center would pull out to load the bike and could be removed to stow it.
91 BG
91 Bus Guy is offline   Reply With Quote
Old 04-07-2013, 05:23 PM   #144
Charley's Avatar
Coachwork: Eldorado
Chassis: Econoline
Rated Cap: 20
Is your lift about the same as the one I found on Ebay Keith?
I have to extend the drive plate to fit my Harley also but that should not be a problem.
The only thing I have to be sure of is that the electric pump can handle the weight of the Harley.
Greetings
Charley
Old 04-07-2013, 05:32 PM   #145
91 Bus Guy's Avatar
Chassis: Chevy G30
Rated Cap: 10
My lift is a Ricon. It was original equipment and was probably built for the heaviest electric chairs of the day. I wish I had an answer for you,but sadly I don't.
Good luck in your search,
Keith
91 BG
Old 04-07-2013, 06:27 PM   #146
Charley's Avatar
Coachwork: Eldorado
Chassis: Econoline
Rated Cap: 20
Ok Keith !
This gives me an idea.
Thanks and I will continue my search for the fender flairs and lift.
Greetings
Charley
Old 04-07-2013, 10:15 PM   #147
browncrown's Avatar
Rated Cap: 79 at Birth
Ricon and Braun lifts on the market today are rated for up to 800 lbs...don't know if that helps or not.
BC
BC
Old 04-08-2013, 07:26 AM   #148
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
For an exact match on the fender flare, you will probably have to go to Eldorado. Most of the bigger van builders( Eldorado is one of the biggest) have that sort of thing custom made for them.
Here's their contact page, they may have a dealer in Germany.
http://www.enconline.com/contact.cfm
I used to haul vans out of the Salina plant. The shipping dept was always great to deal with.
Old 04-08-2013, 09:55 AM   #149
Charley's Avatar
Coachwork: Eldorado
Chassis: Econoline
Rated Cap: 20
BC
800lbs?
That's about 400kg.
It will do the job I think.
Thanks for your info.
Greetings
Charley
Old 04-08-2013, 09:57 AM   #150
Charley's Avatar
Coachwork: Eldorado
Chassis: Econoline
Rated Cap: 20
I have send them an email a few minutes ago.
Thanks
Greetings
Charley
1995 Ford Thomas for Sale Michigan Brian2417 Classifieds | Buy, Sell, Swap 1 12-27-2014 09:57 PM
FOR SALE 1996 Ford Eldorado ptooti Classifieds | Buy, Sell, Swap 1 07-08-2013 07:47 PM
PTooTi's 1996 Ford 7.3L gas E350 Eldorado - Aerotech ptooti Short-Bus Conversion Projects 42 08-31-2012 01:17 PM
1995 ford carpenter 6 cylinder DIESEL for sale ninjabus Classifieds | Buy, Sell, Swap 2 10-10-2010 06:38 PM
1995 Ford/Thomas Built Bus - $2995 Jarlaxle Classifieds | Buy, Sell, Swap 3 04-18-2010 08:56 AM
