10-08-2015, 09:59 AM
#261
That pump is the one I just sent back.
For the Onan, I ordered this one: http://www.amazon.com/gp/product/B00..._prd_ttl_sol_6
I will try this one on the Yam first, we leave on the trip very soon so I need something. If I can get the Onan going, I will re mount it.
Thanks Nate!
Don, Mary and Spooky the cat.
10-08-2015, 12:14 PM
#262
Engine: 466DT
I'm curious how that Airtex works out for you. If it works good, maybe I'll get that one for my backup one then.
10-09-2015, 05:13 PM
#263
The Airtex works the Onan, plenty of flow. I am still having fueling issues, the carb will come of for a good cleaning next.
The AirTex fuels the Yamaha a bit too much even at 1/2 lb pressure.
I mess with it after our upcoming bus trip, for now it's the Yam on the ground and cabled to the bus.
10-27-2015, 07:39 PM
#264
Installed a Planar diesel air heater today. 14k btu, like a little jet engine when it spools up and gets HOT!
Need to fab some fuel tank brackets for a permanent solution. 7L fuel=14 hrs on high thrust.
10-28-2015, 06:57 PM
#265
Tank in and everything tested. Works well.
12-03-2015, 09:39 PM
#266
01-28-2016, 05:24 PM
#267
New carpet top interlocking mat throughout. Just finished, need to mold the edges.
01-28-2016, 05:27 PM
#268
The Planar has been working very well. With outside temps of 30-40 it uses about 1 gal. per 24 hrs.
02-26-2016, 07:53 PM
#269
Chassis: All-American R/E
So where are you at with the genset saga? My Onan runs great after I rebuilt the carb. Parts are almost impossible to find and if you do, expensive. I had to make some small round gaskets out of leather.
I had contemplated the same Yamaha as well.
02-26-2016, 08:31 PM
#270
I did clean the carb and reinstalled with no start...Even with test fuel so I need to address the ignition. I have new plugs, points and cond. but the coil is suspect. I like the Yamaha a lot, very quiet and enough power for our needs. I would like to fabricate an exhaust extension though.
02-26-2016, 08:49 PM
#271
I have a manual for a BFA 4.0 if thats what you have and if you need it. Points on those are a bugger, plus the little plunger thing can get worn out too.
I dont need much power either. Biggest we do is a college dorm type fridge. I have a Champion 4.0 that is a little quieter than the Onan. Starts first pull too, no fuss. I love the Onan, until its cold and I have to fiddle with it. I dont want a diesel.
My deal with the Yamaha was having enough fuel capacity without spending another chunk of money to make it work.
02-27-2016, 12:33 PM
#272
Understood on the fuel volume thing. I'm adding a spare 15 gallon tank to feed my Honda EU3000.
02-29-2016, 06:10 PM
#273
Finally built my spare tire holder. It looks low but it's higher than the front axle.
02-29-2016, 06:33 PM
#274
Looks like my generator rack:
One our generator topic, another generator gem I own:
02-29-2016, 07:18 PM
#275
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
I have the EM600, absolutely love it!
The automatic choke is a PITA though, i will probably convert it to a manual one in the spring.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
02-29-2016, 07:31 PM
#276
nice, right below the battery box, I would have never thought of that, it your spare on a rim?
02-29-2016, 07:41 PM
#277
Yes, it indeed is.
03-25-2016, 05:12 PM
#278
Spare is mounted.
Went with the Pinnella remote kit with a pulse pump. Now I can pump from my onboard 10 gallon gas tank with the genny 1 gal. for reserve.
Charge!!!! /\/\/\/\/\/\/\-
03-31-2016, 08:27 PM
#279
The Pinnella kit worked flawlessly, running the gen twice a day for a 1/2hr. to heat water.
11-07-2016, 06:08 PM
#280
Added an auto transfer switch to our elec. system. Used to just leave the fridge on batts./inv. even when plugged in, now it's on 120v automatically and back to batts. when off grid.
